vent window noise
My truck has all new rubbers in the vent windows but I still have wind noise I used masking tape to find out where the noise came from It is from the rubber gskt to the door frame. Do i have to remove the whole assy and seal behind there or is there an easier fix.
Help al |
CAN'T FIX NOTHIN
Re: vent window noise
Two things happen when you drive a 67 to 72 that wonderfull SQUEAK of the clutch pedal spring and the whistle of the vent windows ! I love em both ! LOL I dont know of a fix for it they just kind of came that way ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Agree. They were noisy when new, so even with new parts that are to the nominal design specification you will probably still get wind noise.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#4 | |
Listen to the radio? what radio...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
I just crack open my driver vent window and the whistle goes away. Even opening the floor vent quiets it down.
Are you talking about the frame to door contact area? That's easy enough to fix with a strip of thin rubber, or foam.
