Reverse drill bits and long drill bits?
Reverse drill bits seems to be a rare tool. Can anyone suggest a good set to have? I like lots of sizes.
I also would love to have a set of drill bits where each bit is several inches long. I know Lowes sells individual bits of like 8" but I'd like to have a set where each one was like 6 inches long, even down to a 1/16". Does anyone know of such a set? |
Re: Reverse drill bits and long drill bits?
Try a machining supply house like MSC. Or maybe McMaster-Carr.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
![]() Join Date: Sep 2005
i bought mine from snap on but they are normal size bits
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
The biggest issue is that a 1/16 drill bit that was 6 inches long would break constantly. The smaller bits get shorter so they don't wobble and because they are less likely to break. You need to look for left handed drill bits not reverse. They should be readily available. I know Snap On has them because I own a set from them.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
what do you use left handed bits for??? undrilling a hole?
![]() i worked construction for many years and have many long drill bits in my collection some 9'' and some 12'' long; 1/4, 3/8, 1/2 and 3/4 have never seen a full set just individual bits many are electricians bits for chasing wires through headers and then there's my 18'' long 7/8'' auger bit for running romex, made for wood but it cuts nails and anything else in it's path harbor fright has a lot of 25'' long wood bits and sets http://www.harborfreight.com/25-long...ece-68823.html
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I agree with the post above, the smaller sized 6" long bits will break frequently.
I think they are commonly used when you want to drill a broken bolt out. Sometimes the bit "catches" and the bolt comes out while drilling.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
That's exactly right. Running the drill in reverse and the bit cutting in a lot of times will extract the bolt without the need for an ez out.
![]() Join Date: Jul 2010
We get all of our drilling consumables from Lawson. They have Left ones. The best for removing broken bolts.
http://www.lawsonproducts.com/
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
