Old 04-02-2014, 04:14 PM   #1
C10Again
C10Again's Avatar
Best headers to use
I've got a 67 4x4 with a sbc auto that is going in it and I need to find some headers for it. What are the better ones to use?
C10Again is offline   Reply With Quote
Old 04-02-2014, 08:02 PM   #2
Billhilly
Billhilly's Avatar
Re: Best headers to use
http://67-72chevytrucks.com/vboard/s...=217490&page=4 Post #80. Hedman 69830. Should be fine with a 67?
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 04-02-2014, 08:51 PM   #3
BLT gmc
C10Again,
I have used JBA 1815 on my 69 K10 4 speed. Shortie style center dump Super quality, do not see why they would not work on the 67 auto. Bruce
BLT gmc is offline   Reply With Quote
Old 04-04-2014, 07:16 PM   #4
Campbel45
Hedman recommended me part number 69092. Ive mocked them up and they look correct but I have yet to actually run them.
Campbel45 is offline   Reply With Quote
Old 04-09-2014, 09:37 AM   #5
jc06vmax
jc06vmax's Avatar
Just put a new set of Summit long tubes on mine. Easiest set of headers I've ever worked with. Went right on, and have been leak free for around 2 months or so. Not sure about the life on them, but fit perfect and worked great so far. I would assume they would fit a 67? I have a 71 Jimmy 4wd.
2006 GMC Sierra VortecMax: LQ9, 4L60e, 2wd, SLE
1971 GMC Jimmy 4x4: 350, TH350, NP205
jc06vmax is offline   Reply With Quote
Old 04-09-2014, 09:12 PM   #6
Campbel45
Just wanted to let you guys know that hedman part# 69092 will not work perfectly with a lifted 4x4! I tried to install them and the passenger side is hitting the shackle. I'm going to see if I can do some bending to get it to work but I'm a little worried about it.
Old 04-09-2014, 10:45 PM   #7
SoCalK20
Don't know if they are the best, my K20 with 350 has long tube Hedmans with a couple of coats of heat paint. Works for me.
SoCalK20 is offline   Reply With Quote
Old 04-10-2014, 08:43 AM   #8
My '72 has Headman Torque Tubes that have been on since '04.I had them ceramic coated,but only the flat black primer. Still doing their thing with nary a touch of a header bolt or collector gasket. I figure their pretty good
