Gauge cluster question
Picked up a cluster from a guy who said it came off of a 85 blazer. It has the fuel gauge next to the speedo, the one I have has the smaller fuel gauge on the lower left and I have the Rpm next to the speedo. Would I just be able to swap this out with any modifications?
Re: Gauge cluster question
No, have to repin the plug in the rear, maybe use your printed cercuit on the back of your cluster.
2024 Silverado Z71 PPV 1972 Chevy Monte Carlo 2018 Buick Enclave (Wifes) |
Ah dang ok
It's definitely do-able but it takes some time and effort. Get both of them off and lay them side by side. Then you need to trace path on the printed circut board and compare the two. Then re-pin.
why are you swapping? They usually go the other way around (try to swap in tach for big fuel gauge).
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Moderator
![]() Join Date: Oct 2008
What's wrong with your tach cluster?
Instrument cluster plug terminals for 73-87 in the FAQ. http://67-72chevytrucks.com/vboard/s...d.php?t=456877
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I'd be curious to know as well. If it's a 78 or newer tach and it's reading too high the fix is fairly simple --> http://howtoalmanac.com/kevin/projec...chfixtruck.htm
We'll I had put aftermarket gauges, then took them out, so I'm missing my oil pressure and coolant temp. My tach doesn't read anything. It only spikes up once when I put the key in. I picked up this other cluster for $10. The truck is 2hours away at my parents house and I plan on driving it to my house and I just wanted to install that cluster with all the gauges just for the trip
78K & 79C Jimmys
i did a swap in my 78 below but it was idiots to gauges,and yes wires need to move
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
| Bookmarks |
