Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-14-2014, 09:31 AM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Thermostat or not
With the new motor i was told to knock the center out of a old thermostat to use as a restictor for the water flow . I have always run a 160 stat in the old motor and have a belt driven pump and fan . I really dont have room for an electric water pump or an electric fan. Just looking for suggestions .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-14-2014, 03:17 PM   #2
low&slow
Re: Thermostat or not
Personally I've never ran a thermostat. Every time I put one in on any of my vehicles, it would overheat within a couple of minutes of driving. I've also never ran an electric fan either. Just a flex fan and no fan shroud.
low&slow is offline   Reply With Quote
Old 04-14-2014, 08:25 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
If your using the pump to circulate water and cool between rounds,,, ya gotta get the thermostat out of the way or it closes and you don't circulate water.
If this is the street truck..
Man on the street I've never had anything but bad luck not running a thermostat in the heat,, and where you are ,, it qualifies as FRICKEN HOT!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-14-2014, 08:41 PM   #4
cableguy0
If a thermostat makes an engine overheat on a street vehicle something else is SERIOUSLY wrong in the cooling system. More than likely radiator too small or improper fan setup such as a fan with no shroud.
My last small block was 10.5-1 compression alum heads and a nasty roller cam. It ran at 200 with a 195 t stat in traffic with the dual electric fans. Stock water pump and stock 4 core brass radiator. Nothing special. On a hard blast running up through high gear it would get to 215 or so but as soon as I took my foot off the loud pedal the temp instantly came back down.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-14-2014, 08:41 PM   #5
BADAZ chevy guy
BADAZ chevy guy's Avatar
Unless you're talking about just during the brake in stage, I wouldn't EVER run an engine without a thermostat.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-14-2014, 09:51 PM   #6
low&slow
I think my motor was fine. Had a brand new water pump on it. All new gaskets. Motor was flushed. Didn't have any leaks. I was running a 4 core radiator. Water was moving just fine through it. I tried a lot of different thermo's for all sorts of different opening temps from cheap ones to high performance ones. Never not once overheated on me while not running a thermo.
Old 04-14-2014, 09:55 PM   #7
cableguy0
What are you calling overheating? Did you have an overflow bottle? What temp did the engine get to?
Old 04-14-2014, 10:00 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
The pump is belt driven off the crank . Seems to be ok . I got to 195 with it gutted . I really need an electric pump and electric fans . I had a 160 in the old motor and it seemed to be alot less smooth on the guage .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-14-2014, 10:01 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
No primarily as a drag truck
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-15-2014, 01:40 AM   #10
71Dragtruck
71Dragtruck's Avatar
For racing electric pump and fans are a must for cooling between rounds IMO, I run that and a Moroso restrictor plate. I had added a drive motor to a Edelbrock high output aluminum pump at first and worked good even though those drive kits are notorious for crapping out. This year I'm now in the process of putting on a Moroso electric pump with one of their one piece billet brackets for a mini Denso and a vac pump.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 04-15-2014, 11:04 AM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
OK , what electric water pump would be suggested ? I have 2 smaller pullers i could put on the radiator . I have a 105 amp alt , but it seems like im just adding alt load . Fans , water pump , MSD , fuel pump , Nitrous , shift noid , lights etc
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-15-2014, 03:00 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Had a nice aluminum hi flow water pump.
Made the the t stat stay shut. Took it off and went back to the plane cast iron and the problem stopped...
160° stat with 3 1/8 holes in it.
165-180° belt driven pump electric fan.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-15-2014, 06:38 PM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Most of the Mezerire style pumps require 7" or so . I dont have that much room . It will have to be remote or belt drive electric .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-15-2014, 10:54 PM   #14
71Dragtruck
Check the length of a moroso for a SB, I know for my BBC it was shorter, mine is only 6 1/4"
Sponsored by:
Hard Candy Customs
