Old 04-16-2014, 11:53 PM   #1
dman1982
dman1982's Avatar
tranny fluid in transfer case
so when pulling my old motor and tranny and tcase, i had tranny fluid coming out the tail shaft of the tcase, now its leaking out the seal by the center of the transfer case, pretty sure that the tranny fluid case this gasket to leak...changing out the fluid tomorrow, and making a new gasket as well...other than the leaks is there any damage that could occur from the 25 miles or so I've driven so far?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-17-2014, 12:57 AM   #2
truckdude239
truckdude239's Avatar
Re: tranny fluid in transfer case
The new tcases use tranny fuild in them look up the proper specs for the fuild. Before filli g it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-17-2014, 12:59 AM   #3
truckdude239
Wait did you use the oringal tranfercase or the newer one that camr with the ls trans?
David fuller
2000 Tahoe 5.3l 378
Old 04-17-2014, 07:21 AM   #4
dman1982
dman1982's Avatar
^^^good questions I'll have to look
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-17-2014, 08:20 AM   #5
dman1982
dman1982's Avatar
I'm using the 208 transfer case, i got a adapter
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-17-2014, 08:41 AM   #6
dman1982
dman1982's Avatar
Here's the stamped placard
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-17-2014, 08:42 AM   #7
dman1982
dman1982's Avatar
Pretty sure it uses gear oil, but just wanted to double check
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-17-2014, 09:14 AM   #8
ls1nova71
ls1nova71's Avatar
208 should use gear lube. The seal between the trans and transfer case are known for going bad and the transmission will pump trans fluid into it causing it to be overfull and leak. Replace the seal and change the gear lube and then check to see how low you are on trans fluid.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-17-2014, 10:42 AM   #9
dman1982
dman1982's Avatar
I'm sure the seal on my new tranny is good, when I pulled the old motor I had fluid coming out the back, I'm gonna change out the seal tonight when I get off work
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-04-2014, 12:18 AM   #10
desertdogg
desertdogg's Avatar
I think you meant it was bad ?
Trying to get thru my LS swap
desertdogg is offline   Reply With Quote
Old 05-04-2014, 12:25 AM   #11
dman1982
dman1982's Avatar
Desertdog, the seal on my old tranny leaked out not my new one, my transfer case is just leaking gear oil now lol...only leak is on the rear housing of my transfer case
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
