Old 04-27-2014, 09:50 PM   #1
Ziegelsteinfaust
Np 203
I got a second 203 with a part time kit installed, and was playing around with the shift linkage to see how it does.
The stock one seems to work right, but is a dual stick kit work it or just a waste of money?
Ziegelsteinfaust is offline   Reply With Quote
Old 04-28-2014, 02:07 AM   #2
andrewmp6
Re: Np 203
If your rock crawling or riding some super tight trails it could come in handy,On a normal 4x4 truck i don't see much use to shift to each axle independently.
andrewmp6 is offline   Reply With Quote
Old 04-28-2014, 10:06 PM   #3
LONGHAIR
Re: Np 203
I would say yes, it is a worth-while up-grade. The original shifters are marginal at best and it doesn't take much dirt/mud to bind one up. Then you are stuck in 4x4 or can't get it into 4x4 when you need it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-29-2014, 12:56 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Np 203
I love using my twin stick, as the stock NP205 shifter had a tendency to wander between shift points and I could never know what my axles were actually doing. Now I can quickly glance at the shifters and know what's going on.
I also like to use 2WD low when I'm maneuvering trailers so that I don't have to feather the clutch as much.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-30-2014, 10:31 AM   #5
Ziegelsteinfaust
Re: Np 203
The 203, and 205 share similar shifters, and I think when I get rolling on spending money after the truck is running a twin stick would be nice. So I will get that instead of rebuilding my factory shifter. As I like to know where I have my gear selection for mpg, and offroad.
Any brands that are recommended?
Old 04-30-2014, 12:10 PM   #6
Redcap
Re: Np 203
You do know that the twin-stick operation is entirely different between the two different cases, right?
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 04-30-2014, 05:53 PM   #7
Ziegelsteinfaust
Re: Np 203
If you read the post you would know I do.
Similar means close but not the same. I could get a dictionary, and send it to you if you want.
Old 04-30-2014, 07:21 PM   #8
tommartin
tommartin's Avatar
Re: Np 203
Just some input, I did a twin stick on my 203.
The single was all greased up and loose, it wouldn’t even put me in loc.
I did a DIY twin stick and it works great. Spent like $10 for some steel and bolts.
No problems yet.
If I had the money to spend on a twin stick kit, I would of got one.
i was thinking of getting this and just making it work:
seen on amazon.com for $77
http://www.amazon.com/gp/offer-listing/B000FPYDH6/... http://www.amazon.com/gp/offer-listing/B000FPYDH6/...
tommartin is offline   Reply With Quote
Old 05-01-2014, 01:05 AM   #9
lowrollin70gmc
Too many projects
Re: Np 203
I used a 3spd stock car shifter from speedway motors and made some linkage with small heims and links from Speedway as well.
Like this one: 49.99 http://www.speedwaymotors.com/3-Spee...fter,1929.html
I have also seen some people use two stock shifters on a longer pivot bolt and some heat/bend of the sticks.
Mine:
(Please ignore the gloopy seam sealer, I swear the welds under it are pretty. And it took a lot of work to undo the previous owners cover cutting and to fit the NV5600 in there.)
Andrew
Old 05-04-2014, 12:55 PM   #10
OrrieG
OrrieG's Avatar
Re: Np 203
Lots of 203 haters her but I have had good experience with mine. Got is used in 1985, had it rebuilt with a Doug Nash shaft conversion kit. Drove it 7K+ miles a year until 2000, with lots of off road in mud, snow, fording streams, etc. without any problems, I always ran out of nerve before potential. Only drawback was the factory shifter, I got real good at jumping under the truck with a big screw driver to get it OUT of 4wd. I converted it to a twin stick, link to thread is below. Drove the truck in new configuration a couple of weeks ago just up and down the street but it seems to be working fine. I never had any issues with need more fluid, etc. but then at least once every two weeks the hubs got locked in and the unit used.
http://67-72chevytrucks.com/vboard/s...d.php?t=360447
OrrieG is offline   Reply With Quote
