Heavy front and rear springs?
I've searched a lot of threads and I am not sure I've found my answer. So here is my question I have a 72 LWB 1/2 ton 350 the spid says I have heavy front and rear coil springs. I want to lower the truck not sure how much yet as I don't want carrier bearing problems and may still need to carry yard stuff from time to time. Can I swap the springs out for standard lowering spring or do I need something special?
Re: Heavy front and rear springs?
Thats a good question...seems like I read somewhere that the factory HD springs are the same as 3/4 ton springs, but I cant say for sure.
I have done lots of research and I think I am going to get 1/2 ton lowering springs for the front and 3/4 ton lowering springs for the rear to retain towing/hauling capabilities. You may have to ask over in the suspension section for more/better info.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
My SPID listed heavy springs front and rear. I used normal lowering springs from ECE and have no issues.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Thanks!! I didn't think I needed any think special but I thought I would check before I spent the money.
Go with the CPP solid aluminum carrier bearing and you will never have issues again. It's far superior to the stock carrier bearings. I went through 2 stock ones, and have had zero issues with this one.
Mike |
