Old 05-29-2014, 04:18 PM   #1
Custom/Ten
Custom/Ten's Avatar
Is this amp gauge working right? (Pics)
So I checked the two 4 amp fuses to see why my new amp gauge was not working. One was missing the other was so corroded that it destroyed the socket when I opened it up. I replace the missing fuse and wired in a 4 amp fuse holder from a radio. Now it works maybe, I'm not sure what do you guys think? When I turn on the headlights it move about an eighth inch to the left, when I start the truck it moves about an eight inch to the right. I expected more. Is this how your guys work? Here's some pics.Name:  image.jpg
Size:  39.1 KBthis is when I turn on headlights, engine off.
Custom/Ten is offline   Reply With Quote
Old 05-29-2014, 04:20 PM   #2
Custom/Ten
Custom/Ten's Avatar
Re: Is this amp gauge working right? (Pics)
This is engine onName:  image.jpg
Old 05-29-2014, 04:22 PM   #3
Custom/Ten
Custom/Ten's Avatar
Size:  43.5 KBLights off engine off
Old 05-29-2014, 04:23 PM   #4
Custom/Ten
Custom/Ten's Avatar
So is that what your amp guauges look like?
Old 05-29-2014, 04:29 PM   #5
hamjet
hamjet's Avatar
It looks to be working fine...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 05-29-2014, 04:33 PM   #6
davepl
davepl's Avatar
Not entirely related, but in my 2+2 I have a 100A alternator and the factory ammenter just PEGS itself when charging hard... probably because the factory unit was 30 or 40A at best I imagine.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-29-2014, 04:42 PM   #7
Custom/Ten
Custom/Ten's Avatar
Awesome thanks hamjet! I pulled the crappy radio fuse holder cause its not waterproof but at least I know how to fix it and just need to find a proper fuse holder and get it soldered in.
Old 05-29-2014, 05:06 PM   #8
Custom/Ten
Custom/Ten's Avatar
Anybody know if I can just take a 30 amp fuse holder from the local parts store and wire that in then put a 4 amp fuse in it? I can't find the original for sale anywhere online.
Old 05-29-2014, 05:14 PM   #9
ole dollor
ole dollor's Avatar
any weather proof fuse holder should work fine . and it would be ok to put the 4 amp fuse in it also ...
ole dollor is offline   Reply With Quote
Old 05-29-2014, 06:59 PM   #10
Andy4639
Old member
Andy4639's Avatar
Talking Re: Is this amp gauge working right? (Pics)
Amp gauge is working fine from what you show and tell. When the truck is off and you put a load on the gauge as the lights being on it is correctly showing a draw on the system to the left of the hash mark with nothing being put back into it.
With the truck on then it should move to the right because the alternator is putting back more than the lights are taking.
Now go buy yourself a good volt meter gauge and hook it up to see what voltage your truck is using.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-29-2014, 11:41 PM   #11
FirstOwner69
FirstOwner69's Avatar
PM me your mailing address, and I'll get an original fuse holder and new fuse in the mail to you next week when I have access to a padded envelope.
Jim
FirstOwner69 is offline   Reply With Quote
Old 05-30-2014, 12:23 AM   #12
Custom/Ten
Custom/Ten's Avatar
Thanks for the help everybody and I apreciate the offer Jim but I found a fuse holder today. Glad to have this sorted out, I'm tired of looking at wiring diagrams haha!
Old 05-30-2014, 02:09 PM   #13
davepl
davepl's Avatar
I thought I'd throw this out there because I -think- it's true and might be useful to others. The ammeter in our trucks (and most vehicles) is not a true ammeter. The current being charged or discharged does not actually run through the gauge, which would take some serious 8 gauge cables to and from it.
There's a sense line that runs from the dash cluster out to the main charging harness. I believe all the ammeter is made up of is a voltage comparator of some sort.
