Old 06-22-2014, 12:32 AM   #1
81GMCSierra1500
81GMCSierra1500's Avatar
1981 GMC Sierra Headlight Issue
Hi all,
I have a 1981 GMC Sierra Classic, with the quad headlight front end, and I've just encountered an issue with my headlights. I'll pull the knob, and everything BUT my headlights will turn on... EXCEPT, when I have my high beams on, the top two headlights turn on to the regular low-beam setting. Just to clarify, when headlights are on W/O high beams, nothing is on, and when I turn the high beams on, the lower bank doesn't turn on, but the upper bank goes to it's "low" setting, and no "high beam" light comes on in the dash either... What's wrong!?!
81GMCSierra1500 is offline   Reply With Quote
Old 06-22-2014, 12:34 AM   #2
81GMCSierra1500
Re: 1981 GMC Sierra Headlight Issue
I'm hoping it's just a pull knob issue, and not a major cost...
Old 06-22-2014, 09:21 PM   #3
Your41Plague12
Your41Plague12's Avatar
Probably a bad dimmer switch. Mine went bad in my '83 once, and it did something similar. It's cheap, so it's probably worth a shot.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 06-23-2014, 12:03 AM   #4
81GMCSierra1500
Update. Went and bought a new dimmer switch, same issue is still happening... could it be my on-floor high beam?
1981 Sierra Classic 1500, 305 4BBL, Ltd. Slip Rear End
Old 06-23-2014, 08:54 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
you can try to jumper the floor headlight dimmer (not dash dimmer) for testing,those wires at the plug heat up some and can melt the plug,worth a peek down there
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-23-2014, 09:40 AM   #6
Your41Plague12
That's what I meant by dimmer switch. It's probably your "high beam switch" on the floor.
Steve
Old 06-23-2014, 11:18 AM   #7
81GMCSierra1500
That's what I thought it was... I will try that, as it was next on my list...
Cheers, guys!
'81
Old 06-24-2014, 08:26 PM   #8
Your41Plague12
Let us know how it worked out. I'm pretty sure that's your problem, the same thing happened in my '83 and that was the culprit.
Steve
Old 06-25-2014, 02:04 AM   #9
81GMCSierra1500
Will do as soon as I'm done with my Grad. Once that's finished, I'll have all summer!
Old 06-25-2014, 08:26 PM   #10
clinebarger
The Delco-Remy floor mounted dimmer switches rarely goes actually bad, They get dirty, 10 to 20 quick stomps on it will fix it (Have the head lamps OFF during this!)
clinebarger is offline   Reply With Quote
Old 06-27-2014, 03:58 PM   #11
81GMCSierra1500
Tried this several times, same thing is happening. I'm thinking it's either the switch or the wiring/plug. I'll take a deeper look at it this weekend.
Old 08-11-2014, 09:07 PM   #12
81GMCSierra1500
Okay, still having the same issue with the headlights, and I am starting to worry... I also, don't want to spend the money on the floor-switch, especially if there's the chance that isn't the issue, same story as when I replaced the main dimmer switch & pull knob... Any thoughts? I will spend the money if I have to, but yeah...
Old 08-11-2014, 09:10 PM   #13
81GMCSierra1500
And adding to the predicament, I have no gauge lighting either... what's happening!?!
Old 08-11-2014, 09:48 PM   #14
larey
Look at this thread "http://67-72chevytrucks.com/vboard/showthread.php?t=545416" and get your manuals first is what I would recommend as it normally shows you what to look for. For your year on page 977 of the repair manual it shows what to look at first and what to test with a multi-meter.
Second part did you have gauge lights before you changed the dimmer switch in the dash?
I looked and could not find a circuit breaker or relay for you set-up except inside your actual headlight switch, on page 1069 which has the schematic on it.
Hope this may help..
Larey
larey is offline   Reply With Quote
Old 08-11-2014, 09:55 PM   #15
81GMCSierra1500
Larey
Larey,
I did not have dash lights before the dimmer swap, nor did I afterwards, but I am thinking the "Gauges" fuse is blown, but it is obstructed by a white plug, which I can't remove, so I won't be able to tell how too get that out... Is there a chance that the headlights are tied into the gauge lighting? and the next thing I'll try to do with the headlights is the floor switch, and if that doesn't work, into the shop she goes!
Old 08-12-2014, 09:09 AM   #16
larey
All the lights are tied into the headlight switch itself looking at the schematic. I would start there before you buy anything else.
Old 08-12-2014, 12:53 PM   #17
81GMCSierra1500
Yeah, I think I'm onto my answer through a different thread, I'm going to replace my main battery-to-frame ground wire, as there's almost nothing left of it. And I already replaced my main switch, and that was most likely a complete waste of money and time...
Old 08-12-2014, 06:05 PM   #18
c3006
Check the two small black ground wires from your headlight sockets to the sheet metal also,those ground wires can cause havoc with the electric system.
c3006 is offline   Reply With Quote
Old 08-12-2014, 06:09 PM   #19
81GMCSierra1500
Yeah, willdo, I just swapped my original battery-to-rad support wire, and that did nothing... I'm going to have to get a pro to look at the old 'gal
Old 08-12-2014, 06:16 PM   #20
Just call me Sean
Just call me Sean's Avatar
Did you check the dash ground yet?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-12-2014, 06:17 PM   #21
81GMCSierra1500
Couldn't find it... Remind me of where it is again?
Old 08-12-2014, 06:19 PM   #22
Just call me Sean
Left of the column. Will be easier to find if you pull out the duct that passes under the column.
Old 08-12-2014, 06:24 PM   #23
81GMCSierra1500
I will work on that tomorrow for sure, I need to get this fixed! I appreciate the help, everyone, especially Sean
Old 02-06-2015, 11:55 AM   #24
TN_Farmboy
81GMC- Did you have any luck with this fix? I've also got a '81 Sierra Classic that is giving me the same issues. I've replaced the dimmer switch to no avail. Trying to get some ideas before throwing stuff at the wall to see what sticks.
Thanks!
TN_Farmboy is offline   Reply With Quote
