Old 06-27-2014, 07:19 AM   #1
Coltronist
Transmission??
Hey! I have a 63 c10 and I made an interesting discovery that I don't have the original motor as I thought. I thought I had a 230 but it turns out it's a 250 inline 6 from a 67-72 c10 (I looked up the Casting number). Now with that being said, I have desperately been trying to identify the transmission I have connected to it.
It's a 3 on the tree manual column, There is NO pan under the transmission, and I found numbers just behind the bell housing on the drivers side that read 37219 as you can barely see in the picture.
Do you guys have any idea what transmission this is?
Coltronist is offline   Reply With Quote
Old 06-27-2014, 07:43 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Transmission??
Zoom out and take an overall picture of the trans from the driver side. From what I'm seeing in that little picture up there, its a Muncie SM318 non synchro 1st gear trans.
Old 06-27-2014, 03:38 PM   #3
Coltronist
Re: Transmission??
Yeah sorry, here is a better picture. Do you like my coathanger linkage pin? Lol
Old 06-27-2014, 03:43 PM   #4
66LSx
66LSx's Avatar
Re: Transmission??
Without seeing the rest of it or being able to count splines...
http://www.nastyz28.com/chevy-manual...tification.php
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 06-27-2014, 04:17 PM   #5
66Submarine
66Submarine's Avatar
Re: Transmission??
Yes, that's the SM318.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 06-27-2014, 04:26 PM   #6
Tx Firefighter
Re: Transmission??
Agree. Its a 318, no doubt.
Old 06-27-2014, 04:46 PM   #7
Coltronist
Re: Transmission??
Thanks so much you guys, do you know if this transmission may have been used original factory in the 63 c10's?
Old 06-27-2014, 04:50 PM   #8
Tx Firefighter
Re: Transmission??
Yes, that would be the original type of trans for a 3 speed truck in 63.
Old 06-27-2014, 04:52 PM   #9
66Submarine
Re: Transmission??
It's the same as what would have came in there.
Looks like you have a high-hump floor/transmission tunnel cover that came from something with a SM420 "granny" four speed with the transmission mounted parking brake. I think '63's had a removable low-hump cover though, so that might be the only thing swapped.
Old 06-27-2014, 05:28 PM   #10
Coltronist
Re: Transmission??
Last question I promise, I'm learning this so bear with me:
Is it possible I can put an over drive gear in and keep it a column shift? Or would I have to move to the floor?
Old 06-27-2014, 05:39 PM   #11
Tx Firefighter
Re: Transmission??
Sure. They were more common than you realize.
Here is a link which explains every detail. Just scroll down a few posts and it gets to the tech.
http://www.jalopyjournal.com/forum/t...needed.685788/
Old 06-27-2014, 06:26 PM   #12
Sharps40
Re: Transmission??
The most significant problem with your truck is not the replacement engine.....the trans is installed upside down.
Sharps40 is offline   Reply With Quote
Old 06-27-2014, 08:36 PM   #13
Coltronist
Re: Transmission??
Yeah so is the engine!
Old 06-29-2014, 06:43 AM   #14
Woogeroo
Wink Re: Transmission??
Yer just getting started... but you are in the right place.
-W
Woogeroo is offline   Reply With Quote
