Old 06-27-2014, 12:26 PM   #1
60paco
steering column question
So i have a 60 column but for some reason they took out the turn signal assembly, i noticed brothers sells the assembly for 63 will that work in my column or do i have to find another column?
60paco is offline   Reply With Quote
Old 06-27-2014, 01:41 PM   #2
1963c-10
1963c-10's Avatar
Re: steering column question
60-62 had different parts on the inside....especially the cancel cams. I'd look for 60-62 parts. I have some sources for them at home that I can post tonight for you. The parts are still available.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-27-2014, 02:51 PM   #3
1963c-10
1963c-10's Avatar
Looks like LMC still has the parts. Link: http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=81
part #14
Old 06-27-2014, 02:53 PM   #4
1963c-10
1963c-10's Avatar
Brothers has them also..
link: http://www.brotherstrucks.com/prodin...number=TSRK060
Old 06-27-2014, 05:28 PM   #5
60paco
well im missing the wiring and everything they basically gutted it for some reason thats why i was windering if i could use the assembly with the wiring from brothers. i have an after market wiring harness so the wring difference wouldnt matter to me. i was hoping to put the 63 cancelling cam and the wiring in my 60 column
Old 06-27-2014, 09:58 PM   #6
ls60apache
60-62 turn signal switch was mounted near base of column actuated by a cable from the cancel cam. 63 up is a better design everything is in the t/s housing.
ls60apache is offline   Reply With Quote
Old 06-29-2014, 05:54 PM   #7
Woogeroo
Wink Re: steering column question
This thread was added to the Steering Column category of your 60-66 FAQ Index.
NOTE : if this link changes in the future, look for the sticky at the top of the 1960-66 Message Board
-W
Woogeroo is offline   Reply With Quote
Old 06-30-2014, 11:52 AM   #8
60paco
so just to clarify can i use the 63 setup in a 60 column?
Old 06-30-2014, 04:33 PM   #9
forestb
forestb's Avatar
no
forestb is offline   Reply With Quote
Old 06-30-2014, 04:57 PM   #10
1963c-10
1963c-10's Avatar
I'm guessing your truck is a 60 by your forum name? And you have a 60 column. Why would you want to convert to 63 parts? Seems it'd be easier and cheaper to replace the missing components and reuse what you have and it would also be correct.
I agree with forestb...I do not think you can use 63 parts in that column, but I do not know for sure. I've always replaced with the correct year parts for what I'm working on. The column wiring and parts are not that hard to install.
Old 06-30-2014, 05:38 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
I have a 1960 GMC, and turn signals were optional. The original owner ordered both line items - front turn signals, and rear turn signals. That provided the entire mechanism inside the steering column. I am assuming if you didn't order the turn signals, there was no mechanism inside the column.
I have also seen several NOS kits on Ebay over the last few months offering the entire OEM kit for installing signals in a 60-62 column. If you want to keep the stock column, I'd start looking there for one of the complete OEM kits that provides the entire turn signal system.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-01-2014, 11:26 AM   #12
60paco
awesome i found the oem setup on ebay you guys have been an awesome help!
