Old 06-30-2014, 01:14 PM   #1
TheBlueBomber
TheBlueBomber's Avatar
Clearance with Dirty Dingo mounts for a 1979 k10?
So I've been fumbling around with these things for a little bit now... basically since I started swapping it in I've had clearance issues with the oil pan hitting the crossmember...
It started out here with the mounts adjusted all the way forward.
And now I've got it dropped down a little more with the mounts adjusted back.
Now I haven't made any adjustments to the long bolts because I ran out of time but I feel like that won't be enough to correct this problem
Now I've spoken to DD and they said you have to notch the frame with these trucks? Yet I haven't seen a single write up on having to perform that notch... they also said on the website under that part number there is a description saying you need to make that notch. Yet there is nothing on the website.
.. here is the link http://dirtydingo.com/store/product_...1369%7B15%7D52
What am I missing here?
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 06-30-2014, 01:18 PM   #2
tinydb84
tinydb84's Avatar
Re: Clearance with Dirty Dingo mounts for a 1979 k10?
What about putting some half inch aluminum spacers under each motor mount?
David
Instagram: myfabguy
Old 06-30-2014, 01:25 PM   #3
TheBlueBomber
I'm going to try that and see how if that helps. For the stock application I think that'll be fine but when it comes time for the turbo set up 1/2" of spacers seems like a lot.
Austin
Old 06-30-2014, 01:25 PM   #4
faribran
The part of the pan that is hitting the frame can be cut off. That is what I did. This is just used for factory harness holder. Or above said, put a spacer in place between engine and mount.
faribran is offline   Reply With Quote
Old 06-30-2014, 01:41 PM   #5
TheBlueBomber
Gotcha. I just wanted to make sure I wasn't the only person with this problem. Did you have any issues with the corner of the block?
Austin
Old 06-30-2014, 02:00 PM   #6
tinydb84
tinydb84's Avatar
That seems like an easier way to go.
David
Instagram: myfabguy
Old 07-01-2014, 08:35 AM   #7
faribran
This cut gave me the clearance I needed. No other contact.
Old 07-02-2014, 08:38 AM   #8
NastyBuzzard
NastyBuzzard's Avatar
Wow so you have the cut the oil pan or cut the xmember when using the dirty dingo mounts? Thats the first I have heard of that.
NastyBuzzard is offline   Reply With Quote
Old 07-03-2014, 07:56 PM   #9
TheBlueBomber
Problem solved!! Put a big pry bar between the DD mount and the frame mount and held it in place while I re-tightened the long bolts. No trimming necessary.
Driver side clearance looks good
As does the passenger side!!
Austin
Old 07-04-2014, 12:06 AM   #10
Daaaanz67
I would think that if you were doing some off roading and a little frame twisting you might move it forward a little since you have clearance with the pan. Just saying.
Daaaanz67 is offline   Reply With Quote
Old 07-04-2014, 09:20 AM   #11
TheBlueBomber
My jack leaks over time so it looks like when I took these pictures the transmission was lowered below where it should be mounted. I jacked it up this morning and at the right height there is plenty of room between the motor and firewall. Good catch.
Austin
