Old 07-01-2014, 08:23 PM   #1
gtbdr
67 fleetside 2wd 5 lug conversion
I want to change my 8 lug front drums over to 5 lug. What yrs will work n any other type vehicles work ?????
gtbdr is offline   Reply With Quote
Old 07-02-2014, 12:43 PM   #2
Diggerdan11
Diggerdan11's Avatar
Re: 67 fleetside 2wd 5 lug conversion
Im am interested in this as well. Hopefully someone pipes up soon.
1969 Chevy C/20 Project- Re-built 350 (more info to come) http://67-72chevytrucks.com/vboard/s...=1#post6377987
1977 Chevy K20 Silverado Camper Special- Future Project
1969 Chevelle Malibu
2011 Yukon XL Denali
2013 VW Passat TDI (Daily)
Diggerdan11 is offline   Reply With Quote
Old 07-02-2014, 12:47 PM   #3
Gruman
Gruman's Avatar
This is something on my to-do list as well! Anybody care to share?
Gruman is offline   Reply With Quote
Old 07-02-2014, 01:32 PM   #4
68blazer
68blazer's Avatar
i have a 68 that had front 6 lug drum. i wanted 5 lug disc. so i bought a crossmember from a 75 1/2 ton chevy and replaced the front end (crossmember/suspension...etc) even though all those year models (73-87) will work i'm real sure that you can just buy different spindles for your year that support what you are wanting. (you will have to buy the rest of the stuff; i.e. rotors, brakes, etc...but you was going to have to do that anyways) I even think that 70 & 71 had 5 lugs from the factory. maybe hunt some of those down??? if you are dropping it you could just buy drop spindles for your year, just my quick .02, good luck
68blazer is offline   Reply With Quote
Old 07-03-2014, 12:27 AM   #5
gtbdr
Just found a bone yard out here that have a cpl tfk 67-72
I met a guy on c.l I got parts from hes got em but keeps giving me excuses about diggin em out
Old 07-03-2014, 09:29 AM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I think Early Classic Enterprises has a conversion.
Tom Vogel is offline   Reply With Quote
Old 07-04-2014, 11:06 AM   #7
Hawghauler
Hawghauler's Avatar
I did this conversion. I bought a '72 crossmember, the frame was cut at the firewall. $150.00. A matching '72 3.07 open rear end. $150.00.
This netted,
Power steering,
all '72 steering linkage,
Disc brake assemblies including good rotors.
Taller gears for highway driving.
Additional expenses:
New calipers at carquest, $25 ea.
New flex brake lines, $25 ish.
New booster with M/C and prop. $225
$20 bucks worth of brake tubing.
$40 for turning drums and discs.
$30 for new shoes and cylinders, springs, etc.
$20 for paint.
Now it drives almost like a car. A pleasure to drive compared to manual everything. A set of 8" rallys and I'm happy.
:Note
Later coil rearends are, I believe, 1 1/2" wider than orginal '67s.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 07-04-2014, 08:42 PM   #8
OKGMC4
OKGMC4's Avatar
This post has maybe more info than you'll ever need...
http://67-72chevytrucks.com/vboard/s...d.php?t=456889
I personally used a set of 73-87 front control arms and spindles on my 69. Easier to find in the junkyard and the bushings and ball joints are cheaper when you rebuild them. They bolted right to the crossmember, didn't have to change the k member at all. Just make sure you use parts matched to the year you pulled from, even steering linkage.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 07-06-2014, 12:55 PM   #9
gtbdr
Going to bone yard tues hopefully they wont ream me. Thanks guys
