Old 07-08-2014, 01:34 AM   #1
67chevy_hotrod
67chevy_hotrod's Avatar
trying to decipher my engine codes
So i have my 67 Chevy with a rebuilt small block. The Casting number is 3970010 so i take it its fair to assume its a 350 correct? I am also aware that there is another code i need to pull that i can find on the passenger side of the engine? is this on the head or on the block or what? please help me out i would love to know the history of this engine also i know that 350's were not put in 67 so is there a chance this could be the original 327? I am dying to know and any wisdom and or knowledge is greatly appreciated!!!
67chevy_hotrod is offline   Reply With Quote
Old 07-08-2014, 03:18 AM   #2
LSUMurse
LSUMurse's Avatar
Re: trying to decipher my engine codes
I have no answers other than to visit this site. It makes my eyes go crossed, but I'm kinda simple headed.
Nasty Z28
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 07-08-2014, 03:19 AM   #3
mechanicalman
It's probably a 69-80 350 2 or 4 bolt main. It could be a 327 2 bolt main or even a 302 4 bolt main but I doubt it. Despite not being a 67 original engine, it's still a good block. No matter what it's a 4 inch standard bore block with 68 and up style large journals with pretty good iron alloy. I give your odds of having a 4 bolt main about 90% if it's a pickup engine and about 10% if it's a passenger car engine. Does it still have the serial number stamped onto the RF corner of the deck? Here is a good site for casting number description.
http://webpages.charter.net/darrell1...g_numbers.html
Last edited by mechanicalman; 07-08-2014 at 03:20 AM. Reason: Left out informative link.
mechanicalman is offline   Reply With Quote
Old 07-08-2014, 10:32 PM   #4
67chevy_hotrod
So! I just got the chance to investigate and the block hasnt been decked so as clear as daylight i could pull the code 14B514299 is that the only number on the deck there or is there another one i can find i only scraped off enough paint to see this number! and thanks a ton for the help!
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
Old 07-08-2014, 10:35 PM   #5
67chevy_hotrod
Okay I scraped off more paint and found K01 28 CMR. I have no idea in how to decode this like what is the suffix code and does the 14B mean its a 1-Chevy (obviously) 4-1974 B-Baltimore? did i do that right?
1967 Chevy CST 10
1969 K10 Suburban
Old 07-08-2014, 11:57 PM   #6
70c10stepside
It is indeed a 350. High nickel block. The 'best' stock block. Came in both 2 and 4 bolt mains.
70c10stepside is offline   Reply With Quote
Old 07-09-2014, 12:06 AM   #7
67chevy_hotrod
Good to know! Are you able to Figure out the Engine id code? and VIN code?
1967 Chevy CST 10
1969 K10 Suburban
Old 07-09-2014, 02:42 AM   #8
mechanicalman
I think it's a 74 Chevelle engine came with 2bl carb, 145hp. Are you going to rebuild it?
Old 07-09-2014, 06:57 AM   #9
SS Tim
SS Tim's Avatar
1 Chevrolet
4 1974
B Baltimore MD (vehicle assembly plant)
514299 sequence number
K St. Catherines, Ontario (engine plant)
01 January
28 28th day
CMR L-65 350/145hp/2bbl/automatic "A" body (Chevelle)
SS Tim is offline   Reply With Quote
Old 07-10-2014, 12:36 PM   #10
67chevy_hotrod
thanks guys! i am going to rebuild it eventually but it is far from its original 145HP. Its been bored .30 over and it has Hedman Ceramic long tube headers, Edelbrock Performer Intake a Huge cam previous owner didnt know the specs i guess? To top it all off its got a 750 Holley double pumper. Not the best setup i get like 5 mpg, it runs really rich to keep the idle low enough so it doesn't diesel. I dont know how much power it puts out but its fast as hell and will roast the tires through 2nd. Its got really tall gears so it gets all the way up to like 70 and calls it quits. its all the way up to like 4000 rpms.
1967 Chevy CST 10
1969 K10 Suburban
