Old 07-11-2014, 10:19 PM   #1
plumbers crack
plumbers crack's Avatar
Tach with Lil fuel gauge
I found one after searching dozens of yards. I cleaned it up, painted the needles and installed it and the fuel gauge works. Does any one know how many pulses the tach needs to work? I have a few options for signal out put for the cummins but need to know the pulses so I can order the right unit.
The donor truck was a top kick with the 8.3 or something non turbo cat engine.
1990 GMC R35 CC dually, VE cummins, 47RH
2005 Silverado ecsb, 5.3, 2/4 drop, daily work wagon
2000 Yukon xl, 5.3 all stock, wife's truck
2007 Yukon Denali, 6.2 back up truck
plumbers crack is offline   Reply With Quote
Old 07-11-2014, 10:46 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Tach with Lil fuel gauge
Now you just need a clock.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 07-11-2014, 10:51 PM   #3
plumbers crack
Yes sir, when I find one worth using.
Old 07-11-2014, 10:57 PM   #4
t_graham11
I just went to look at a shortbed frame and can across a cluster just like that I paid the guy cash right there offered him 100$ for it... We got to talking and he is I ended up with an amazing deal, frame, can complete with interior and a new fuel tank and sender all for 300$
That's the beauty about old chevy owners they pass on the generosity to each other
t_graham11 is offline   Reply With Quote
Old 07-12-2014, 01:15 PM   #5
hatzie
Moderator
hatzie's Avatar
Cat Diesel Tach. I believe it runs off a tap in the windings of the alternator so Pulley diameter ratio and the number of poles in the alternator will all enter into it. If you're not driving it with the same Diesel alternator with the same diameter crank pulley you'll have some head scratching to do.
I'd start by setting up a bench experiment to drive the tach with a DC power supply, audio frequency generator, and frequency counter. Then I'd record the frequency to RPM relationship every 500 RPM.
Then I'd attach the frequency counter to a stator tap on the AC side of the diodes in your alternator and observe the frequency vs RPM from the alternator...
Some "Light Reading"
http://www.cumminsforum.com/forum/89...ring-tach.html
http://www.dieselplace.com/forum/63-...lead-tach.html
http://www.turbodieselregister.com/t...for-tach-drive
http://forums.qrz.com/showthread.php...r-driven-Tachs
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-12-2014, 10:52 PM   #6
bdiamond
Is that km/h? 140 mph speedo would be cool....
bdiamond is offline   Reply With Quote
Old 07-12-2014, 11:08 PM   #7
Just call me Sean
Yes kilometers, he's in Canada. I wonder if you could regear the speedometer gears to make it read correctly as MPH.
Old 07-13-2014, 12:01 AM   #8
plumbers crack
Hatzie, it is all making sense now, guess I have to make a trip to the wreakers where the gauge came from and measure the crank and alt pulley and pull the alt. I have to spend a few hours searching here again too see if anyone has got one of these tach to work.
Old 07-13-2014, 12:04 AM   #9
plumbers crack
The speedo is in kph. The iroc speedo might be 140 mph.
Old 07-13-2014, 01:58 AM   #10
mr.chevyblack
mr.chevyblack's Avatar
all you need is a dakota digital dsl-1 hooks to the altnator and give you your 8 cly pulse out put you would need for a cummins ive done it on a few of my trucks
mr.chevyblack is offline   Reply With Quote
Old 07-13-2014, 08:22 AM   #11
hatzie
Moderator
hatzie's Avatar
For a Gasoline engine tach...
His tach is off a Cat Diesel in a 40-60 series heavy hauler and it's going on his Cummins...
"The donor truck was a top kick with the 8.3 or something non turbo cat engine."
Old 07-13-2014, 11:28 AM   #12
wraprail
wraprail's Avatar
150mph speedo even better
wraprail is offline   Reply With Quote
Old 07-13-2014, 08:56 PM   #13
ray_mcavoy
Many of the GM medium duty trucks with diesel engines used a magnetic pickup mounted near the flywheel for the tachometer signal.
Here's some info from an old GM service bulletin:
If this applies to your tach, the required pulses per revolution will equal the number of teeth on the donor truck's flywheel.
ray_mcavoy is offline   Reply With Quote
Old 07-13-2014, 09:20 PM   #14
hatzie
Moderator
hatzie's Avatar
The plot thickens...
Bunch of worthwhile info out there in TSB sheets...
Old 07-13-2014, 10:32 PM   #15
plumbers crack
Where did you get that from? That is great info, I must have really good look at the donor truck, see which it is. I should have scratched down the vin.
Old 07-13-2014, 10:53 PM   #16
meatwagon83
meatwagon83's Avatar
i would love one of those clusters, guess i need to keep my eyes peeled
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 07-14-2014, 02:18 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
looks good,nice score!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-14-2014, 07:06 PM   #18
hatzie
Moderator
hatzie's Avatar
I have a few TSBs from the 70's but haven't had time to scan them. You see them at swapmeets sometimes. I've seen that one before but I don't believe it's in my hardcopies.
Old 12-30-2014, 08:54 PM   #19
plumbers crack
I had a little time today to play with the tach and hook it up to my 89 gmc plow truck, it worked but at 2000rpm it read 250rpm. At idle it read just off the peg.
I've searched for shops in my area for someone to get me sorted with figuring out the pulses per but came up with nothing. I'm hoping that the Dakota digital box will work with its adjustability.
Old 12-30-2014, 11:26 PM   #20
86c20
86c20's Avatar
that cat motor is a 3208. its a v8 so the gas v8 tach will work back and forth. as long as sender is the same. alt or mag or what ever still 8 pluse
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 12-31-2014, 04:35 AM   #21
nonstop
I went through this hooking mine up. It picks up off the flywheel teeth. I found a magnetic pick up, drilled a hole in the bellhousing and wired one wire to ground with the other to the tach. It works, but is off since the 454 uses a 168 tooth flywheel and the medium duty trucks use different counts on their flywheels.
nonstop is offline   Reply With Quote
