Old 07-14-2014, 08:51 PM   #1
1966
eBay Ram Horn Manifolds (2 choices)
Any input on either of these? Or are ram horns hard to screw up...
http://www.ebay.com/itm/321431626131 (includes mystery bolts and gaskets - $124.95 DLVD)
http://www.ebay.com/itm/310951136962 (no hardware - $123.90 DLVD)
1966 is offline   Reply With Quote
Old 07-14-2014, 09:08 PM   #2
jtrichard
Re: eBay Ram Horn Manifolds (2 choices)
first set is for non smog I would think if you are going with the rams horn look you are trying for oem look if so you would NOT want the second set UNLESS you have a smog pump on yours
jtrichard is offline   Reply With Quote
Old 07-14-2014, 09:10 PM   #3
1966
No smog equipment in my truck. Is that what those bolts are for on the front of the manifolds in the 2nd listing?
Old 07-14-2014, 09:49 PM   #4
bhc41051
bhc41051's Avatar
You might want to consider looking for a good used set. I think you'll be pleased with the fit and finish of an OEM set.
bhc41051 is offline   Reply With Quote
Old 07-14-2014, 09:53 PM   #5
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
why not move up to 2 1/2". neither of those examples is. they look to be 2" (I know one of the selections describes the outlet as being 2 3/8" but that is the measurement to the outside of the sealing bevel, not the pipe diameter. I got burned by just that sort of measurement on a set of e-bay manifolds before).
Larry
fleetsidelarry is offline   Reply With Quote
Old 07-14-2014, 10:44 PM   #6
1966
Haven't been able to find OEM for less than $100+ per side, and that's rusted to hell and back. Dorman & Wysco seem to be $120-$140 per side via JEGS etc... Don't really want to spend $200-$300 on them. Any suggestions?
I did just find these:
http://www.ebay.com/itm/201120760217
*** Will 327 ram horns work on a 350? Found these, could just saw off the bracket:
http://www.summitracing.com/parts/rn...FRWVfgodnlEAig
They're going to mating up with 2-1/4" HeartThrob exhaust system, would I just need a reducer? Have zero exhaust knowledge...
Old 07-14-2014, 11:42 PM   #7
jtrichard
Those are pipe plugs more or less yes they are for the injection tubes (SMOG) 327 and trefitty should be the same.....sounds like the first ones would match your pipes
Old 07-15-2014, 08:12 AM   #8
fleetsidelarry
Senior Car Nut
1966, yes the originals are pricey. the 1st set I bought for the 350 in my '66 was oem and I paid $225 if I remember right. after one broke (my fault) I replaced it with a $59 aftermarket. I'd say, if you don't need brackets buy the set without them.
how does the HeartThrob system attach at the manifold end? since the ramshorns take a pipe with a end that's built for a donut gasket with a stub pipe that fits up into the manifold, you'd want to make sure the one's you buy are the size you need. Zoom in on the ones in your link http://www.ebay.com/itm/201120760217. notice the machined area where the exhaust pipe fits.
those in your first post look like 2" to me but jtrichard may be right.
Larry
Old 07-15-2014, 09:29 AM   #9
cru_zn_29
cru_zn_29's Avatar
Do you need to mount your alternator on left side?
cru_zn_29 is offline   Reply With Quote
Old 07-15-2014, 10:02 AM   #10
MikeN
MikeN's Avatar
i just went through this on my 64 C10. Hated the headers, wanted factory rams horn manifolds. Here's what I learned;
1) It's not too terribly hard to find a nice, used LH manifold with 2.5" outlet at a decent price. They came on some Impalas, but the boss for alternator mounting is DIFFERENT than a Corvette, so the Corvette guys haven't bought them all up and driven the prices up.
2) The Corvette guys HAVE bought up all the good RH manifolds with 2.5" outlet, due to the fact that the Impala and Corvette castings are essentially the same. I bought a nice reproduction RH manifold with 2.5" outlet from a place called Crane's Corvette Parts. You really can't tell it apart from a factory casting.
All that said, I did spend more than it sounds like you are wanting to spend. I think I ended up spending about $250 for the pair. I've had them on my truck for several months now, and LOVE them. They sound good, look good, and fit good.
MikeN is offline   Reply With Quote
Old 07-15-2014, 02:16 PM   #11
pimpston65
pimpston65's Avatar
i troll CL for parts with good luck/cheap you may need to drive to get em, but its cheap and sometimes u find other parts from their stash!!!
pimpston65 is offline   Reply With Quote
Old 07-15-2014, 03:32 PM   #12
1966
From the research I've done it seems like my setup would be better served doing 2.5" exhaust, and the HeartThrob is 2.25". I'm just gonna keep my eyes peeled for a set of GM manifolds and have the shop fab up a 2.5" system. Searching this forum and a few others leads me to believe a pre-fab 2.5" exhaust for a 350 doesn't really exist. Almost pulled the trigger on the Wysco Ram Horn Manifolds though.
Old 07-15-2014, 04:51 PM   #13
66Submarine
66Submarine's Avatar
FWIW, Rockauto.com has the Dorman 2-1/2" outlet manifolds for <$50 each + shipping.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-15-2014, 06:08 PM   #14
donthekawguy
donthekawguy's Avatar
http://spokane.craigslist.org/pts/4569046318.html
66 shorty
donthekawguy is offline   Reply With Quote
Old 07-15-2014, 06:50 PM   #15
1966
My alternator is mounted to the block via bracket.
Do you have a part # ? All I can see are the angle-dump for $80.79
Originally Posted by donthekawguy View Post
Just emailed them! Thanks!
Old 07-15-2014, 07:02 PM   #16
1966
Last question (sorry), it is true you can use two RH manifolds instead of a LH and RH? I could just buy 2 OEM right side manifolds and not have to worry about cutting off the generator bracket on the LH (?) Or are they side-specific?
Old 07-15-2014, 07:56 PM   #17
fleetsidelarry
Senior Car Nut
other than the brackets, the ones that dump straight down are the same, left and right
Larry
Old 07-15-2014, 08:13 PM   #18
1966
ok that solves a lot of problems then, thanks for the info
Old 07-15-2014, 08:54 PM   #19
66Submarine
Do you have a part # ? All I can see are the angle-dump for $80.79!
I punched in 1962 Corvette and they come right up; Dorman P/N 674503 and 674504.
Old 07-15-2014, 08:55 PM   #20
1966
Sorry I was looking under the wrong year. I really appreciate the info!
Old 07-15-2014, 11:22 PM   #21
Slow Build
Slow Build's Avatar
Here's a picture showing the difference between 2" and 2.5". It doesn't sound like a big difference, but it's a huge difference.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 07-15-2014, 11:24 PM   #22
1966
oh wow, yeah that is impressive
Old 07-16-2014, 06:41 AM   #23
donthekawguy
I have had good luck with buying parts and having them sent COD from people on CL. A couple of people don't get it but most know if you don't pay they are sent back or they don't want the hassle. Good luck!
66 shorty
Old 07-16-2014, 01:19 PM   #24
jtrichard
early (at least) OEM are not the same left and right the left is set up for doughnut gasket and the right had a flat gasket for the heat riser (not tapered for the doughnut) the bottom face of the riser was tapered ........ if you look at the craigslist post you will see the right one has longer studs for the riser http://spokane.craigslist.org/pts/4569046318.html
