Old 07-16-2014, 09:57 AM   #1
1971 cheburban
327/350 head and intake questions
I have a freshly done 350 block, and I wanted to know if I can run 327 heads(491,492s,etc.) with a smaller combustion chamber.the main reason is edelbrock has the ram log 6x1 intake and says it only is for 283-327. So I thought maybe I can run 327 heads and use that intake but on my 350 block, anybody have any experience on this subject or can explain why that 6 carb intake won't work on regular 350 heads I'd appreciate it
1971 cheburban is offline   Reply With Quote
Old 07-16-2014, 10:08 AM   #2
67 chevelle
67 chevelle's Avatar
Re: 327/350 head and intake questions
should be the same , the heads will interchange ,and the only reason the old intake would not fit is if you have newer than 96 "vortec" heads
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-16-2014, 10:15 AM   #3
1971 cheburban
That's what I thought, but I did t know if I put 327 heads on it and block some water passages or something, it is a 1970 350 block, and I'm going to try to find 327 heads to bump up the compression and maybe this 6 carb intake, it's going in a 1962 biscayne so it's going to look old school
Old 07-16-2014, 10:35 AM   #4
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
They are not talking about the heads when they say 283 327 they are talking about the block the 283 327 blocks have a breather in the back of the block and no holes in the valve covers the oil is poured in the engine thru the intake in the front , the heads fit from 1955 to whenever they stopped mmaking smmmall block chevy engines but as mentioned above the vortec heads are different ,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 07-16-2014, 03:11 PM   #5
1971 cheburban
So I can use the intake on a 350 but there is a hole in the intake for the oil fill. Is there something they make to block that off where I can fill it through the valve cover like a normal small block, or do I jut have to give up on on having a 6x1 intake on a 350
Old 07-16-2014, 03:59 PM   #6
geezer#99
geezer#99's Avatar
Yes you can use it on a 350.
No it doesn't have a hole for an oil fill tube.
Just a thermostat hole and a distributor hole plus heater hose hole.
http://www.edelbrock.com/automotive/...-quad-sb.shtml
Old 07-16-2014, 04:00 PM   #7
19673ontree
CAN'T FIX NOTHIN
You can block off the hole with a freeze plug and use it with any pre 1987 heads you like
underdash AC
Old 07-16-2014, 04:04 PM   #8
19673ontree
CAN'T FIX NOTHIN
If an intake has the oil filler hole you can block it off the one pictured does not , also edelbrock advertises items to fit the 283 & 327 because those engines are pre smog ,,, they know you are gonna use them on engines newer but they cant say that ,,,
underdash AC
