Old 07-31-2014, 08:47 PM   #1
demok83
demok83's Avatar
Transmission fluid leak?
Hey guys, I noticed today some fluid dripping off of my transmission. My truck is an 83 silverado with a th350. It appeared to be leaking out of my speedometer cable. I tightened it and it has appeared to stop. It is also dripping off my driveshaft, and it appears to be coming out of it. Is that possible? Please forgive my lack of knowledge, I've just started working on trucks. It is a big learning curve, but I absolutely love it! What could be causing the leak? Also, I took a picture of something (last pic) that I didn't know what it was. Any help? Thanks!
demok83 is offline   Reply With Quote
Old 07-31-2014, 11:25 PM   #2
TrybalRage
Re: Transmission fluid leak?
Fluid tends to travel so it's hard to get a bearing on where a leak is coming from when it's all over the place. Get some brake cleaner and hose the area down to clean the existing stuff off, and wipe it down afterwards. Then you can see where the actual leak may be coming from.
TrybalRage is offline   Reply With Quote
Old 08-01-2014, 10:31 AM   #3
notallthere
That is what mine looked like and it was the speedo gear seal.
notallthere is offline   Reply With Quote
Old 08-01-2014, 11:04 AM   #4
Oldriginal86
There are several threads on this, do a search on "Drive Shaft Leaks". Should be some sort of cup and o-ring in the transmission that keeps the fluid from creeping down the splines and out the vent.
Oldriginal86 is offline   Reply With Quote
