Old 08-05-2014, 08:08 AM   #1
Edahall
Blower motor rebuild
My blower motor keeps quitting but if I hit it hard with a metal bar, it'll start running again. After a while, it starts running slow so I have to whack it again. What's wrong with it and can it be rebuilt?
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 08-05-2014, 08:45 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Blower motor rebuild
there is probably a bad gear in there or a bearing that allows something to get away from what is driving it.. I don't know whether it can be rebuilt it depends on damages once you take it apart and the availability of parts
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-05-2014, 03:57 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
Just get a new one at AZ or OReillys, 25 bones and it will blow more air
Malo83 is offline   Reply With Quote
Old 08-05-2014, 05:29 PM   #4
Edahall
Price must have gone up. They're over $50 now.
Old 08-05-2014, 08:41 PM   #5
Rubble
I wouldn't even bother trying to rebuild it,remove & replace.I replaced the heater core in my crew last fall & did the blower motor same time,you can't put a price on a blower motor when it's -40 deg C.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 08-06-2014, 12:17 PM   #6
Malo83
Cruzzzn' Vet
Malo83's Avatar
This is the one I put in my 83, kicked up the output of air
http://www.oreillyauto.com/site/c/de...&keyword=pm129
Old 08-06-2014, 12:51 PM   #7
mrolds88
If you are looking for a "cheap to get me by for a while" fix, drill a 1/16" hole in the top of the "bump" in the middle of the end of the blower motor and spray a small bit of wd40 in it, run for a while then put a few drops of 3-n-1 or other light oil in it.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-06-2014, 02:56 PM   #8
parrisc19844x4_468
parrisc19844x4_468's Avatar
How hard is it to replace? Mine makes a nose at start up then quits , but annoying.
found one at CARQUEST for 18.39
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 08-06-2014, 03:13 PM   #9
MountainGoat1966
Attachment 1286419
The motor comes out real easy, 5 screws I believe, 1/4" hex head.
The fun part is changing the fan itself.
You have to reach down inside the fan to remove a clip that holds the fan to the motor shaft.
Personally, I would rather spend a couple bucks more and get a motor with fan already attached.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 08-06-2014, 03:27 PM   #10
parrisc19844x4_468
I have my dash out right now, getting it recovered, I will check it out. Maybe it is the just the fan that is making the noise.
Old 08-06-2014, 03:30 PM   #11
parrisc19844x4_468
right below the motor, there is one with a fan attached. I will go for that one.
thanks
Old 08-06-2014, 03:35 PM   #12
MountainGoat1966
The blower motor and fan assembly come out from the engine compartment side.
Check to see if mice and packrats made a nest in the fan housing like they did on mine.
It made a lot of noise with their crud in there.
Old 08-06-2014, 03:44 PM   #13
parrisc19844x4_468
Thanks for that. I assumed it was in the cab.
