CPP spindles with stock calipers
Ok getting the front end back together. Can't afford to upgrade brakes right now. Went with the CPP drop spindles. Had to buy the HD 1.25 rotors to go on spindles. Was told I could use stock calipers , just needed to order a bracket from CPP to attach stock calipers to spindles. Attached bracket and calipers with new pads wont fit over the rotor. Gap between pads fully retracted piston is 1.125. Do I need different calipers? Any feed back would be nice.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: CPP spindles with stock calipers
You have to use HD calipers to match your HD rotors.
LOL. That makes sense. Picked them up today for 14 bucks a piece. All slide together nicely.
| Bookmarks |
