Wiper switch ?
So have any of you seen this wiper switch like this one? And can I get it to work on my 78? Thanks for the help.
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
#2 | |
Re: Wiper switch ?
Looks like the one in my '83.
Re: Wiper switch ?
That's a delay wiper switch, and I don't think it will work on a 78. It requires a delay module in the dash and a flat wiper motor. Is your motor rounded?
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Re: Wiper switch ?
My wiper motor is getting replaced hear soon so I can get what ever one I need to to make it work. The motor that it has does not look flat to me so I would say no. There is a box attached to the back of the switch. Hear is a pic. Let me know what you think.
Re: Wiper switch ?
I see you got the delay box, too, that's a good thing. If you want to make all that work, you will need a 79 or later motor and the wires. I was going to do this on my 77 but never could find all the parts, so just gave up on that and put it on a 79 I had. That one was just plug and play.
Moderator
![]() Join Date: Oct 2008
Re: Wiper switch ?
That's the whole 78-83 delay switch and module. 78 definitely had delay wipers as an option not just 79 & later. Yes you can get it to work on your 78 and later if you pay attention to the schematic and if the delay module is working.
The GM schematics call out Delphi #12004706 plug on the standard and delay wiper harness. Meaning the same harness plug connects to the delay box or the standard wiper switch. You may be able to plug it right in and get delay wipers. These 1970's delay modules were made with discrete components... Relays, Transistors, Resistors, and Capacitors... not usually microchips or if they included a chip it was a unit like the good old 555/556 that you can buy anywhere. Discrete electronic circuits are pretty tough and they can be repaired by an enterprising soul with a little electronics knowledge... Even a burnt trace can be repaired As long as GM didn't POT them like the late '80s delay modules or the 73-75 tachs. http://www.rowand.net/Shop/Tech/DelayWipers.htm Delay wipers were an option in 77 but it's a very different animal from the 78-83 units and a fairly rare option too.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-20-2014 at 09:10 PM. |
Re: Wiper switch ?
I had that option on my 78 back in the day.
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale |
78K & 79C Jimmys
Re: Wiper switch ?
I found one in the JY cleaned it and it works,in my 78
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 08-18-2014 at 08:46 AM. |
78K & 79C Jimmys
Re: Wiper switch ?
and it was plug and play for me
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: Wiper switch ?
Thanks motornut and hatzie I'm going to get on putting it in some time this week.
Re: Wiper switch ?
Ok now I got problems! So I hooked it up and the first click of the selector does nothing then the 2 & 3 do the normal fast and faster. So I took it apart, lost the ball bearing then improvised, cleaned it then tried it again. Still same result? Bad switch or is the wiper motor just not ment for that switch?
#12 | |
Moderator
Re: Wiper switch ?
I'd have to draw up a schematic of the module to really troubleshoot it. Motornut That board is so extremely simple it could be duplicated in an afternoon. 2 TO92 package Transistors and a bunch of Electrolytic Capacitors, Resistors, Diodes, and a DIP Chip. Is that TO220 package device on the bottom of the board a FET or Voltage Regulator? What numbers are on the DIP chip? My money would be on some variant of the 556 or some other '70s era timing chip. I may have to buy one to satisfy my curiosity. See what you did...
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-18-2014 at 10:28 PM. |
#13 |
78K & 79C Jimmys
Re: Wiper switch ?
Motornut
That board is so extremely simple it could be duplicated in an afternoon. 2 TO92 package Transistors and a bunch of Electrolytic Capacitors, Resistors, Diodes, and a DIP Chip. Is that TO220 package device on the bottom of the board a FET or Voltage Regulator? What numbers are on the DIP chip? My money would be on some variant of the 556 or some other '70s era timing chip. I may have to buy one to satisfy my curiosity. See what you did... [/QUOTE]a couple more shots, yes could prob make boards up even easier these days
#14 |
Re: Wiper switch ?
A 4001 CMOS is a quad nor gate. I used to build astable oscillators using the 4011 quad nand gate with students when I taught electronics. I imagine a 4001 could be wired similarily. A 555 of 556 would be easier, and is the main chip in most of the old aftermarket intermittent wiper modules.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#15 |
Re: Wiper switch ?
Following along as I would like to add this option to my 77.
#16 |
Re: Wiper switch ?
Ok so u got it working, had to jimmy rig it though. When I pulled I must have bent the copper peace that turns the wiper on furring the window washing mode. So I couldn't get it bent back into place do I just clipped it off! I don't have any of the window washing peaces anyway! But it works now! Thanks for all the help guys
| Bookmarks |
