Old 08-26-2014, 09:30 PM   #1
BIG DADDYS 84
What happened??
OK,just completed,rear end swap and drop,1984 step,sb and long tail shaft 350, installed shackles and hangers,removed overload spring,dropped 4and1/2" and if it matters its a 2wd and i installed another 10and1/2 rear end .but it is a 6lug from the same year.installed new center bolts and new u-bolts.heres the problem my drive shaft is now too long.it is jambed into the trans.had to force it in rear yoke.its too long? the other thing is i replaced the rear shocks with new front shocks,read that would work,problem with shocks is they are too short,will not stretch to lower bracket?need some help,thanks in advance,you guys always come through
BIG DADDYS 84 is offline   Reply With Quote
Old 08-26-2014, 09:39 PM   #2
71swb4x4
71swb4x4's Avatar
Re: What happened??
You dropped the truck, the rearend is now closer to the transmission. As you decrease the driveshaft angle you are also decreasing the distance from the rearend to the transmission. Most people probably don't see enough of a difference to worry about it but you probably had the perfect storm and have the right combo where you are seeing a problem.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-26-2014, 09:39 PM   #3
86c20
86c20's Avatar
Re: What happened??
well think man the rear end moves up and down and as it does the shaft gets longer or shorter and now you have shorten the over all leangh. also some rears has a longer poinon shaft then others and it sounds like yours is from a heavy half or something more heavy duty
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 08-26-2014, 09:54 PM   #4
BIG DADDYS 84
Re: What happened??
so is a new drive shaft in order?
Old 08-26-2014, 09:55 PM   #5
BIG DADDYS 84
Re: What happened??
and do i need to change angle? shims? thanks
Old 08-26-2014, 10:04 PM   #6
Jake Wade
Jake Wade's Avatar
Re: What happened??
Are you trying to install the driveshaft with the weight off the wheels?
Jake Wade is offline   Reply With Quote
Old 08-26-2014, 10:31 PM   #7
BIG DADDYS 84
Re: What happened??
no shes on the ground,but its just too short on ground or lifted,
Old 08-26-2014, 10:42 PM   #8
Jake Wade
Jake Wade's Avatar
Re: What happened??
Sounds like driveshaft mod time.
Old 08-27-2014, 08:08 AM   #9
Keith Seymore
Keith Seymore's Avatar
Re: What happened??
Yes - or shorten the one you have.
I'd wait and see what you've got once you get the new/modded shaft installed, and go from there.
You are straightening the angles out, which is favorable in terms of vibration. You will just want them equal and in opposite directions when done.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-27-2014, 09:27 AM   #10
BIG DADDYS 84
Re: What happened??
thanks guys,on the way to machine shop,drive shaft guy says may only need to shorten 7/8"? is that enough? also looks like I need shock extensions
Old 08-27-2014, 10:07 PM   #11
71swb4x4
71swb4x4's Avatar
Re: What happened??
I would do shock relocators before shock extensions. Have you corrected the shock angle yet?
