09-15-2014, 11:24 AM | #1 |
Side Mirror Mystery Holes... Anyone recognize?
So I finally got around to adding the OEM side view mirrors on my 1970 CST/10. (I'll leave the pure joy and excitement of installation for another thread...)
I found these two holes (see pics) on both sides. They look factory, although I have no idea which OEM mirror used only two holes in this odd location. Don't mind the smaller holes they were from an after market mirror. Ideas? Thanks!
1967 C10: My next project 1964 SS Impala Hardtop, low and slow 2007 Harley Street Glide .... When all else fails to start. |
09-15-2014, 11:45 AM | #2 |
Member #1049
Re: Side Mirror Mystery Holes... Anyone recognize?
Those are for the factory 67-70 style mirrors, there should be one more hole just above and slightly forward of the front screw in your "71-72" sport mirror.
09-15-2014, 11:50 AM | #3 |
I thought of that. But there isn't a third hole on either side, only two. And, isn't that mirror 67-69?
Thanks for pic!
09-15-2014, 11:53 AM | #4 |
Member #1049
I would be willing to bet there is one there, just plugged, The sport mirror you have is a 71-72 version only, The Blazer pictured is a 70 with factory paint and OEM mirror on the tub
09-15-2014, 12:24 PM | #5 |
I was just going by what the catalogs show, and they don't give that option for 70-72. Is you blazer a different cab? It has 67-68 frond end.
Thanks.
09-15-2014, 12:27 PM | #6 |
Member #1049
Yes the Blazer pictured is a 70 with a 68 clip,
Here is another picture of a factory 1970 2WD Blazer I had with original paint. |
09-15-2014, 01:57 PM | #7 |
I'm backing livrat up on this one the third hole must be welded or bondo'd up they probably thought since the new mirrors would cover 2 holes they would save time possibly money by only filling one hole on both sides. And I also agree that the three screw mount with the arm is a 67-70 truck/blazer/suburban mirror. I had a 70 Chevy 4wd with those Mirriors from the factory. And IMO the 67-70 style mirror and mirror arm is much easier to see out of and does give the sw trucks a nice old school look and I don't think they look bad at all.
09-15-2014, 02:41 PM | #8 |
Look close. I think you can see the filled third hole in the pic.
CHEVY/GMC VIN DECODERS |
09-15-2014, 02:46 PM | #9 |
That's awesome, I'll check it out when I get home!
How did you use the circle tool? You guys rock!!
09-15-2014, 03:05 PM | #10 |
Florida Edition
Good eye Bruceman!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-15-2014, 03:19 PM | #11 |
Just used the ellipse tool in Photoshop. Curious to see what you find out when you get home.
