![]() ![]() Join Date: Sep 2008
My Longhorn went missing
This board is so valuable in so many ways.
My 71 big block C2500 had the symptoms of vapor locking. It missed under load, seemed to run out of fuel when extremely hot outside and under load. I had changed the fuel filters twice, moved the fuel line around to make sure it wasn't touching anything, new tank and sending unit, new rubber hoses, new fuel pump, all to no avail. I'm sorry I don't know who to give credit to, but I saw a post on here about the positive wire to the HEI partially missing or damaged causing similar symptoms to mine. I checked mine and sure enough, someone had just twisted the wire together and taped it. I stripped the wire clean, soldered it together, put the shrink wrap on and problem fixed. So simple I keep expecting the symptoms to return.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
The Older Generation
Re: My Longhorn went missing
The knowledge on this board never ceases to amaze me. That is one of those problems that you could chase forever if you hadn't read that post and remembered it.... LockDoc
![]() Join Date: Nov 2004
Based on your title... Thought it was stolen....
Congrats on the simple fix.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Before I found the problem, I wished a couple of times somebody would steal it.
Funny how you can go from happy to sad and vise/versa so quickly with these old rigs.
Moderator
![]() Join Date: Jun 2008
Whew! You scared me. I'm glad it was never missing, but only missing, and now it's not missing because you found the problem
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#6 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Moderator
![]() Join Date: May 2007
I know what you mean. Having to chase a driveline vibration is one of those painful things too. After having an alignment, new u-joints, carrier bearing, driveshaft balanced, new harmonic balancer, tires balanced, wheel bearings checked...the truck still had vibration problems. Talking to a boardmember here with the same problem revealed a bad water pump could be the issue. Problem solved.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#8 | |
#9 | |
Sorry, I didn't mean for this to be confusing. To clear things up, it wasn't really missing, it was just missing.
