Old 10-02-2014, 07:35 PM   #1
John Pasinski
John Pasinski's Avatar
Trailering a cab
I'm picking up a '72 cab. I've reserved an open 6' X 12' trailer. I'll also be renting a pick up to bring back the front clip and engine.
Unable to rent (at this time) a larger trailer.
My questions are: Can I fit the cab on a 6' wide trailer?
If so; can I set on the floor and strap it down w/o damaging the underside?
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 10-02-2014, 08:31 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Trailering a cab
I don't see a problem with that, I've seen pics on here with cabs in the beds of full size pickups.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-02-2014, 08:38 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Like HubScrub said the cab will fit in a full size pickup bed, but I have never hauled one that way. When I haul them on the trailer I always put a pallet under them.
LockDoc
Leon
Old 10-02-2014, 08:38 PM   #4
71swb4x4
71swb4x4's Avatar
I hauled mine in the back of my pickup. If you have a pickup I would haul it in the bed.
I put a couple tires underneath it to protect the cab corners.
6x12 is way more than enough room. Put the cab on sideways, you will have more room than you know what to do with.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-03-2014, 06:46 AM   #5
Grumpy old man
Grumpy old man's Avatar
You can fit all your bringing home just in the trailer .
Grumpy old man is offline   Reply With Quote
Old 10-03-2014, 08:51 AM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
Or you could do it this way.......
Sorry John, couldn't help my self
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-03-2014, 08:56 AM   #7
John Pasinski
That's OK Brad. Someday..............I may be able to use my truck that way too.
Old 10-03-2014, 09:27 AM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I think it can be done...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-03-2014, 10:32 AM   #9
Shaky
Six in a row makes it go...
Shaky's Avatar
Just did it on a 5x10:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 10-15-2014, 01:06 AM   #10
TheBreeze
I put mine in an s-10 short box, used tires and ratchet straps to stabilize. The tailgate shut, and it rode fine for 100 miles back home.
TheBreeze is offline   Reply With Quote
Old 10-15-2014, 08:00 PM   #11
Dale_Brown
This worked just fine.
Dale_Brown is offline   Reply With Quote
Old 10-15-2014, 08:46 PM   #12
Savidio44
Savidio44's Avatar
Smile Re: Trailering a cab
The cab fits in a full sized pickup...............bring 4 strong guys!
Savidio44 is offline   Reply With Quote
