Old 10-06-2014, 09:17 PM   #1
Drewkimble48
88-94 c1500 gauge disassembly
Have any of you fellas taken one apart before and successfully put it back together? If not, is there a place that can break into it to change the mileage to match what my truck has now?
I recently acquired a gauge cluster that comes with the Tachometer and would love to install it and have it reflect my mileage. Any help would be greatly appreciated.
Have a great week guys!
Drewkimble48 is offline   Reply With Quote
Old 10-06-2014, 10:11 PM   #2
mountie
mountie's Avatar
Re: 88-94 c1500 gauge disassembly
Yup... I replaced the light bulbs...... place the panel on a static-safe surface.
A manual shows the screws...... or just do it..... a couple layers / of a panel, starting from the rear side.
Not tough to do...
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 10-06-2014, 10:14 PM   #3
Drewkimble48
Not tough to do...
Ok so I don't even have to take the gauge face off, just come in from the back side with those screws and it should come apart
Old 10-07-2014, 05:13 PM   #4
mountie
mountie's Avatar
Uh, yea.... sort of.....
You can clean the inside clear plastic while you're at it
Once it's out, you can remove the (3?) 'levels' of boards.... I think there's a couple little harness plugs..... You'll expose all the bulbs if you wish to replace 'em...... I remember you will get to the mileage counter at some point.
Watch where the gear selector cable connects to the column/shifter barrel. ( it just pushes on the edge, kinda like a elec. connection..... there will be a worn spot.
