![]() Join Date: Feb 2001
67,68,69 TH400 kickdown switch
TH400 kickdown and partial wiring. $45 shipped to you.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
![]() Join Date: Sep 2011
Re: 67,68,69 TH400 kickdown switch
In line......Has the switch been tested?
1967 C10 SWB Owner - Rustbelt Restorations |
Not tested, just pulled off 1969 GMC I parted and put on shelf. How do you test them - I've got a 12V power supply?
JQ
If I tested it right, the switch works. I hooked my 12V power supply to the terminal where the red wire was. I then attached a test light to the orange wire and when I engaged the switch, the test light would illuminate.
JQ
I will take it if the other deal does not go thru.
It's yours, toyplumbertrucks! I'll PM payment info.
JQ
| Bookmarks |
