69 pro touring/ autocross.
Sold my 68 step ls1 truck and decided I wanted a little nicer truck with a great handling suspension and of course ls drivetrain. The truck as I bought from a friend . He has already put rockers in and started shaving the firewall .
![]() Got my ride tech front adjustable coilover suspension. ![]() Installing a high hump tunnel . Truck will have a built t56. ![]() ![]() Cut holes in crossmember and welded in 4" pipe to rout exhaust through. Welded up my trailing arms ![]() Got a factory core support with the truck that was in pretty good shape with the exception of minor rust on the bottom so I made some patch panels and welded them in. ![]() ![]() Got some in rail notches and started fitting them in lastnight. On the way I have a complete new bed 18x10 wheels front and rear , my t56, and I pick up a 2004 ls1 on Tuesday. I've got started on my engine wiring harnes. This is just a mock up motor. ![]() I'll be running this holley intake with a adapter I made to run the t.b. vertical using a round carb style air filter assembly.
| Bookmarks |
