Old 11-21-2014, 01:28 PM   #1
chris989
water in #7 cylinder
Hello all,
I have water getting into #7 cylinder. I pulled the head last night and can not locate a crack and the head gasket showed no signs of failure.
I see a water jacket running under the intake, Is that a possible source of the water? Does the 5.7 TBI motor have a common failure that i can not see?
The motor is tired and not worth much. I honestly thought it would be a head gasket and back together already. I just wanted to have it running/driving as i prepped a new motor i am building for a swap.
Chris
chris989 is offline   Reply With Quote
Old 12-05-2014, 03:13 AM   #2
chris989
Re: water in #7 cylinder
update,
after very detailed inspection with a magnifying glass, i could see it was only the head gasket.
all back together, no cracks.
Old 12-07-2014, 07:03 PM   #3
man7sell
man7sell's Avatar
That's great. Mine got water into exactly the same cylinder, turned out a little worse as it got stopped the engine when trying to start up. You lucked out
Capt. Paul Mansell
1974 Chevy Stepside
man7sell is offline   Reply With Quote
Old 12-07-2014, 07:39 PM   #4
chris989
Mine hydro locked 20 miles from home. Until then i had no idea i had an issue unit i tried to start it. I got lucky as it did not destroy the motor. I bumped the starter a few times thinking it was a flywheel starter issue. Lucky more me my motor is a little tired and the water bypassed the rings/valves finally and it started.
It is running great now, 331,000 on this 350 and still doesn't more than a quart every 5k miles.
