Old 11-27-2014, 01:09 AM   #1
CRGRS 66
CRGRS 66's Avatar
Door Hinge Repair/Rebuild
Hey guys, I don't see anything in the FAQ'S on fixing door hinges. Do I press the pins out, or do I need to grind off the end of the pin that I am pointing to in the picture? I am pretty sure that I ordered new pins, have to check my new parts stash.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 11-27-2014, 02:00 AM   #2
boat
boat's Avatar
Re: Door Hinge Repair/Rebuild
I grind mine down and punched it out and replaced with new one, I have a video on doing mine but don't know how to put it on here
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4
boat is offline   Reply With Quote
Old 11-27-2014, 09:22 AM   #3
CRGRS 66
CRGRS 66's Avatar
Thank you, if you have the video on you tube, could you post the link?
Craigerrr
Old 11-27-2014, 10:08 AM   #4
62 Barnfind
62 Barnfind's Avatar
I used a cut off wheel to cut the ends off. The sprayed with WD 40 and knocked them out. The replacements are longer so I cut them to look like the originals.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 11-27-2014, 12:45 PM   #5
boat
boat's Avatar
Haven't posted a link in a while but you can go to Gibson63 on YouTube that's my Channel after rebuilding my hinges they worked fine after installing on the cab
