Old 12-08-2014, 05:21 PM   #1
95gmc
Newbie with a problem 95 gmc
So I am new here I've been a long time lurker of the site. But I have a problem I have a 95 gmc 2wd with a 5speed. I went out this morning to start it, and the key wouldn't turn and the steering wheel was locked. The steering wheel is not tightly locked but the wheels are straight. I've rocked the truck back In forth in gear, turned the steering wheel left and right trying to free up the cylinder and nothing has happened. I've unplugged the battery disabled the airbag rented a steering wheel puller and got a new key and tumblr. Then I was starting to pull the steering wheel. But I cannot get the airbag out. I have got one side out, but can't get the other. This is becoming a big pain as it is hangin up my daily driver. Any tips or tricks to get the tumblr to roll? Any advice. I've searched and have found very little information on this. Thank you very much for your help!!
95gmc is offline   Reply With Quote
Old 12-08-2014, 08:26 PM   #2
95gmc
Re: Newbie with a problem 95 gmc
Any help is greatly appreciated
Old 12-09-2014, 09:42 AM   #3
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Here are a couple Captain Obvious questions that I'm sure you've already thought of:
1.) Have you tried rocking the steering wheel back and forth as you're trying to turn the key?
2.) Are you absolutely sure you're trying the correct key?
killthewabbit is offline   Reply With Quote
Old 12-09-2014, 10:20 AM   #4
95 S_Trucker
95 S_Trucker's Avatar
I would try a new key from the dealer. They can cut one from the vin. Its $15-20
The keys get worn and then you have to wiggle and jiggle the key to get the cylinder to turn.
95 S_Trucker is offline   Reply With Quote
Old 12-09-2014, 11:16 AM   #5
95gmc
I'm %100 positive it's the right key. I have two keys, one has recently been cut within the past two months. I've used it three times and it's worked everytime. So it's not the key as I've tried both of them. Yes I've rocked the steering wheel while trying to turn the key.
Old 12-09-2014, 12:25 PM   #6
95gmc
I have heard of drilling the tumbler out?
Old 12-09-2014, 03:28 PM   #7
mattybilt79
I have only ever seen one ign switch jam to to point of not being able to start it. If I remember correctly you don't pull the steering wheel on 10 cut ign switch it requires a special curved stiff wire to release the switch from the housing I have done a few back in my repo days but that was 10 years ago. If you can't get it by wiggling the key around call a locksmith before you break something. Our 95 hoe is really worn to the point that other people can't turn the ign switch but either of us hop in and crank it right over.
85 3+3 with a tee-pee
mattybilt79 is offline   Reply With Quote
Old 12-09-2014, 04:07 PM   #8
95gmc
I've wiggled and jiggled it around. Put lube in the cylinder, nothing at all is working. And there is hardly no information out there about this. Thank you for all the replies this far!
Old 12-09-2014, 04:49 PM   #9
95gmc
Someone has had this problem before, insure of it. Someone has had to replace a tumbler that was jammed up. Any help please!!!! This is my daily driver and I've been messing with it since yesterday. I really need some kind of input. Should I just drill it out? Won't that release the pins
Old 12-09-2014, 05:01 PM   #10
mattybilt79
Like I said and it is if I remember correctly the switch is held in by a spring loaded tab like a woodruff key. Drilling it won't do anything except make a mess. Call a locksmith to come pull it out for you only way to do it that I know of without busting the switch out requires that special tool.
Old 12-09-2014, 11:24 PM   #11
95gmc
For anybody else having this problem this is what I found. And it worked for me!
http://youtu.be/R7D3mxFwp4M
Old 12-10-2014, 10:48 AM   #12
95 S_Trucker
When you buy the new cylinder, get it from the dealer. They will code it so you wont be annoyed with having one key for the door, and one key for the ignition. I would still recommend a new key cut from the vin, not a copy of a worn old key.
Old 12-11-2014, 03:21 PM   #13
mattybilt79
That's a neat trick will have to remember that one. I only ever pulled switches without keys which requires the special tool to release the ignition lock.
Old 12-11-2014, 11:07 PM   #14
95gmc
It worked like a charm. I'm glad I found it, and I hope this helps out somebody else that has this problem.
Old 01-07-2015, 10:11 PM   #15
youngblood78
I had a problem like this one time had my tumbler lock up when I started my truck starter still going mortor runing lets say I got to that battery real quick did the jiggle and it went to working right for a few minutes then it locked up truck runing and I couldnt shut it off lucky I had a pretty smart auto body teacher in high school baled me out lol
94 Silverado 1500 ext. Cab short bed 350 nv4500 (factory)
78 K20 350 (soon to be 400sbc if I can find one) sm465 205 dana44 14bff 6in lift on 37" militarys
youngblood78 is offline   Reply With Quote
