Old 12-16-2014, 01:18 AM   #1
HSRACER
HSRACER's Avatar
New to me and need some guidance
I just bought this 64 shortbed with a 292 3 speed manual trans with a 3.08 rear gear. The challenge is the trans does not have a synchro 1st gear and when trying to turn corners that are to slow for second gear it is all but impossible to get it in 1st until you are almost stopped.
Is there a 3 speed that will replace the one in my truck with a synchro 1st gear. I really like the 3.08 rear gear for highway driving.
Any potential easy and inexpensive options to my problems would be appreciated. Thanks
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 12-16-2014, 01:24 AM   #2
HSRACER
HSRACER's Avatar
Re: New to me and need some guidance
Here is a picture
HSRACER
Slammed 53 5 window
Old 12-16-2014, 01:28 AM   #3
HSRACER
HSRACER's Avatar
Darn I phone posting!
HSRACER
Slammed 53 5 window
Old 12-16-2014, 01:32 AM   #4
joedoh
joedoh's Avatar
double clutch. push clutch in shift from second to NEUTRAL let clutch out. Push clutch back in shift to first. once you start doing it you wont be able to un do it.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-16-2014, 01:51 AM   #5
HSRACER
HSRACER's Avatar
Will that really work? Isn't there a synchroed 3 speed?
HSRACER
Slammed 53 5 window
Old 12-16-2014, 02:22 AM   #6
joedoh
joedoh's Avatar
of course it works! thats how everyone shifted before syncros. I think later 3 speeds were syncro 1st, but that one is not. your problem is the 3.08 rear gear makes it work on the highway but hard to drive at low speeds.
I forgot to mention, you need to blip the throttle a bit to get the revs up before shifting into first.
you could always lug it out in second, the 292 has a ton of bottom end torque.
Old 12-16-2014, 07:54 AM   #7
Mr Bear
Leave it in Second. Slip the clutch, wind the engine up. If its pulling at1000 to 1200+ rpm, it'll pull all but the steepest incline while turning. Its a long stroke torque motor. Don't be afraid to use it.
Mr Bear is offline   Reply With Quote
Old 12-16-2014, 09:12 AM   #8
Ta2Don
Ta2Don's Avatar
Double clutch...
learned that trick long ago...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-16-2014, 12:30 PM   #9
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Here's how I shift to 1st...66 chevy c10 with an sm420 4 speed with granny low....shift down to 2nd...let the truck slow down to idle...Without pushing the clutch in pop it out of 2nd..tap the gas as you pop it out...then slide up to 1st by rev matching....meaning reving the engine to the speed it would take to go that speed in 1st and it'll fall right in. Its really easy to do, especially when ya get the hang of it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-16-2014, 01:32 PM   #10
61K10
61K10's Avatar
66 or 67 chevy car and truck and later Saginaw 3 speeds are all synchro
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-17-2014, 11:00 AM   #11
Bears63
...just another truck junkie..
Bears63's Avatar
Learn to double clutch and you will have learned something that is literally a dying art. Impress your friends with your clutch skills!
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 12-18-2014, 09:29 AM   #12
C-10cutty
C-10cutty's Avatar
Sweet truck.
C-10cutty is offline   Reply With Quote
