Old 12-18-2014, 09:25 PM   #1
hubcap
Brake light wiring problem
Have a 98 chevy c1500 when you hit the brakes it blows the fuse. Unhooked the brake switch all other lights work fine.Looked for a bad wire around switch and under dash but saw none. Does the wire run up the steering column. Though I would look up there. Any ideas Thanks
hubcap is offline   Reply With Quote
