Old 12-23-2014, 09:30 AM   #1
Unionwelder
Unionwelder's Avatar
Fuel filler length
Hey guys, I'm swapping my cab tank for a frame style. My question is does the length of the filler neck matter? What I'm planning on doing is running a stainless ep tube from the tank back into the cab from underneath to the original filler cap. (I like the look of the filler on the side of the cab) but want to make sure the length of tube won't effect anything. Vapor problems etc.
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 12-23-2014, 09:44 AM   #2
cdowns
cdowns's Avatar
Re: Fuel filler length
A long neck with numerous bends will b pretty much impossible to fill up in a timely matter
Old 12-23-2014, 12:09 PM   #3
Hart_Rod
Hart_Rod's Avatar
If would be much easier if you made dummy filler cap out of the original fuel filler cap and hide the actual fuel filler behind the rear side marker light or the tail light.
Hart_Rod is offline   Reply With Quote
Old 12-23-2014, 03:07 PM   #4
Unionwelder
i like the way that looks, is that a hinge you can buy or homemade? And may be a stupid question but won't the electrical connection and gas fumes be a problem together?
-Sterling
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Old 12-23-2014, 03:10 PM   #5
Bigdav160
Bigdav160's Avatar
That appears to be an european style cabinet hinge
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-23-2014, 03:40 PM   #6
Hart_Rod
Hart_Rod's Avatar
Home Deport. Not a lot of arcing and sparking back there...
Got it at Home Depot,
http://67-72chevytrucks.com/vboard/s...d.php?t=380571
Old 12-23-2014, 07:57 PM   #7
Unionwelder
10-4 thanks guys I'll check into it.
-Sterling
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
