Old 08-20-2003, 02:52 PM   #1
cochino12
It followed me home?
cochino12's Avatar
changing color
I have been thinking of changing the color of some of my interor trim like the dash and console. Problem is every type of dye (sp) and paint I get, I can still scratch off. What brand of stuff have you guys used to change the color of your plastic and maybe your steering column?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-20-2003, 03:25 PM   #2
Gibble
mmmm....Rye and Coke
Gibble's Avatar
don't you remember what your mother used to tell you
"Don't pick at that!"
Actually, I'm curious too
Gibble is offline   Reply With Quote
Old 08-20-2003, 04:58 PM   #3
gldevall
gldevall's Avatar
I never could get paint to stick on the plastic in my S-10 Blazer I had so I ended up having everything wrapped in greay tweed. It looked good but it cost about $600. Our trucks would be a lot cheaper b/c there is nowhere near the amount of plastic that was in the blazer.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 08-21-2003, 07:18 AM   #4
bagged81
Signals in the bumper.
bagged81's Avatar
I used SEM Interior paint on all the plastic stuff and the dash. It seems to hold up pretty good on everything. I have scratched a few pieces and the paint did not come off. Only time will tell though. I do have to be careful with the dash however cause it seems to be more susceptible to scratching maybe cause its surface is softer. I am having my column paint with PPG base coat/clear coat.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 08-21-2003, 09:45 AM   #5
Gibble
Gibble's Avatar
Btw, did you prime before painting?
Lightly sand the panels, lay down some good primer, then paint, it should stick better
Old 08-21-2003, 10:37 AM   #6
TROYLV
plastic paint
rustoleum has come out with a plastic primer paint. when i find some i am going to try it. says it will make any topcoat stick to plastic. check their web site out.
troy wilson
TROYLV is offline   Reply With Quote
Old 08-21-2003, 10:41 AM   #7
Gibble
Gibble's Avatar
I know for my dash, since I'm filling the cracks, I'm sanding it smoothish, priming, putting on rockerguard for texture, then painting some krylon plasitc paint over it
The krylon plastic paint is supposed to be somewhat like plastic when it goes on, and be very durable. We'll see
Maybe I'll get my dash done tonight and I'll give an update
