Turbo 350 dumping fluid
When I drive my 67 C-10 it never leaks tranny fluid. But when I park it for a few weeks, it dumps about 2 Qts. This seems to be a fairly common problem with 350's. What gives? Thanks
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
where is it wet at the pan or inspection cover or both and might be the speedo is on drivers side or dipstick tube there is a seal on passenger side
72 cst 2wd blazer sb soon to have tilt manual 72 gmc swb fleet 2wd bb air tilt auto 93 c/3500 crew-cab dually 03 chevy suburban LT quadrasteer c/2500 4x4 |
Large Member
![]() Join Date: Jun 2002
Also, do you park it on level ground or it facing up or down?
Watch out for your cornhole !
![]() Join Date: Jun 2003
There is a little check valve inside that is supposed to keep the fluid in the torque converter. When the valve leaks, the converter fluid will drain back into the tranny and leak out of any place it can. That's why it only happens when it sets for awhile. If you drive it occasionally, the fluid stays pumped up into the converter.
I changed every seal in my TH350 twice, before my tranny guy explained what was happening.
