Quiz Time - Topic: Passenger Front Fender
How well do you know your Square Body?
How many bolts/screws do you have to remove in order to remove the passenger side front fender (by itself, nothing else hanging off of it) from a square body truck (73-87 third gen C/K I think) the screws that hold the badge do not count, etc. A. 15 B. 20 C. 25 D. 30 Extra Credit: Let us know where the bolts are located that you would be removing I hope I counted right, LOL |
Re: Quiz Time - Topic: Passenger Front Fender
As a game changer be advised that the factory installed the fender with the wheelhouse already on it (the fender).
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
i am going to guess 15. A final answer lol 5 on the back 2 for hood 2 at the top of core suport 3 in head light trim and 3 in the bottom fille and brace. and that is with not cheating and going out to look. to damn cold lol
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
not a bad start, the answer is more (5 on the back? not sure what you mean by those)
by the door. one in the a piller then 2 in the firewall and two at the bottom.
that is just a guess and that is with no inner fender or anything of the like. i think if you add in the inner fender annd the plastic at the bottom and the batt try got to be over 25
I installed about 1.8 million squarebody fenders (900,000 per side; or one per minute per side over a six year period) so I don't think it would be fair for me to participate in your quiz...
I believe it is 25, Keith correct me if I am wrong
here they are in no particular order fist the big ones 3 - 9/16ths attach to the hood hinge bracket 1 - 9/16ths above the top door hinge 1 - 9/16ths under the truck door sort of 1 - 9/16ths on top behind hood hinges then the smaller ones 7 - 1/2 inchers attach to the inner fender 5 - 1/2" attach to the radiator support on the inside 2 - 1/2" bolt on the side of the battery tray 2 - 1/2" above the headlight inside that cavity 1 - 1/2" left of the parking light inside that cavity then the tinny ones 2 - philips screws hold the light bezel to the front of the fender |
I found a front clip on craigslist the other day. I pulled it apart laying in the dirt and snow, there was at least 50 rusty bolts on each side, and they all had to be at least 3 feet long!! Can't wait to ditch my poor fitting aftermarket junk though.
LOL, awesome, so worth it though, thanks for sharing
#11 | ||
(I would have forgotten to count the phillips screws - lol). Those small 1/2" bolts are the ones I am talking about when I tell my favorite "bolt substitution" story: Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-05-2015 at 05:27 PM. |
And if you have a fender mounted antenna you'll need to add one additional nut to remove the cable. Three phillips screws if you have the factory am/fm/cb antenna.
Alex. |
#13 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Keith "I'll match your fender install, and raise you 1,799,999 fenders" Seymore.
#14 | |
what about that 1/2" bolt substitution story? lemme get a beer |
#15 | |
(lol) Seriously though, if one were to do the math: 1 per minute = 60 per hour x 8 hours per day = 480 per day. 480 a day x 285 working days per year x 6 years = 820,800 fenders x2 (one on each side) = 1,641,600. ...Assuming no overtime.... ![]() Plus: tightening the box down, hanging the spare, installing the M20 shifters and cab running lights, putting the battery tray(s) in and underhood wiring. And putting the SPID labels in the glovebox. All in a day's work. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-06-2015 at 12:18 PM. |
| Bookmarks |
