NP 205 wiring to dash
Brain fart here....
84 K30 with a NP 205 Looking at the wiring of the 205, I see the hot comes from the fuse panel section A with a 20amp fuse. With my IP, the 4x4 indicator is built into the speedometer above the left turn indicator. With this following wire diagram I believe its for the 4x4 indicator thats in the left of the IP where the clock would be. By reading the back of the IP printed circuit the wire will come in at pin #14, wire 141 ( Brown / White )to the bulb and out to printed circuit ground. So would I be reading this right? 1. Forget all about the #150 ( Black ) ground wire to bus bar ground. 2. Attach #141 ( Brown / White ) to #150B ( Black ) that is the switch wire 3. Attach # 156B ( White ) to IP pin#14 and allow the IP to make the final ground.
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles 91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles 96 K15 Sub 350/4L60/243c/10 bolt 333k miles |
| Bookmarks |
