Old 08-21-2003, 12:50 PM   #1
Nightrider
Nightrider's Avatar
posi going bye-bye-help!
if someone could answer a question about my posi, she's hanging up on my blazer 4 WD, bad around corners, and vibrating on the highway. Is ther anyway to fix this without tearing the whole thing apart and replacing the ring and pinion or can I just put a new LOc-Right or Posi unit in there. I wish to fix on the cheap, but I know how that goes. thanks
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 08-21-2003, 02:05 PM   #2
cdowns
cdowns's Avatar
there's no crystal ball for fixing rears that i know of !! the only way i'm familar with is take it apart see whats damaged repair/replace, if it's done cheap you've got cheap
Old 08-21-2003, 02:18 PM   #3
VTKidder
A rear end is usually like a tranny; things are moving so fast and so close together in there, that by the time you hear noise or feel vibration, the damage is done. If it's an axle bearing on the inside of the pumpkin (or outside for that matter), I know they make bearings which are offset; they will be lined up with the same spot on the axle, but ride about one bearing width to the inside in case your blown bearing wore down the axle shaft. That gives you a little extra life. No choice but to pull the cover and check it; it's a simple project.
VTKidder is offline   Reply With Quote
Old 08-21-2003, 09:38 PM   #4
Nightrider
Nightrider's Avatar
posi
yeah, axle bearings are easy on each end , but my posi with the clutches not engaging correctly is a little different. I'm not paying some dumbass at pep boys 15000.00 to look at my diff. I've got a Eagle with a 6v92 and allison trans I've pulled out and reinstalled. I need to know should rebuild the whole thing or try to just replace the posi unit... Everything I have is old and needs money , I do'nt want to pay for something I can do... thanks bros for any infor... E
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-22-2003, 04:17 AM   #5
tickets
bad posi
2 words, Detroit Locker. it aint cheep but they ROCK!!!
tickets is offline   Reply With Quote
Old 08-22-2003, 07:31 AM   #6
Ed ke6bnl
Re: posi going bye-bye-help!
I sure don't now much about rear ends but My old gmc posi was doing some strange stuff and I put a bottle of the limit slip additive quited it up, just a suggestion.
ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
