Old 01-09-2015, 08:45 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
help!help!
will a 59 half ton apache rear end work on my 63 half ton c10 ??any info will be much appreciated thanks
1966FLEETSIDE is offline   Reply With Quote
Old 01-09-2015, 09:39 PM   #2
Trap62
Trap62's Avatar
Re: help!help!
If your talking stepside then here's a link that discusses the interchangeability between the different series.
http://www.mar-k.com/bed_side_interchange_gm.aspx
Trap62 is offline   Reply With Quote
Old 01-09-2015, 09:59 PM   #3
PGSigns
PGSigns's Avatar
Re: help!help!
If you are talking about the rear end the answer is no.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-09-2015, 11:39 PM   #4
frankslagoon
Re: help!help!
just changed the rear axle ass. in 63 c 10 went to a 66 I'd say ya can't go down only up. the frames are different. is that the deal guys?
frankslagoon is offline   Reply With Quote
Old 01-09-2015, 11:40 PM   #5
1966FLEETSIDE
Re: help!help!
Trap good information thx but I was referring to the rear end.Jimmy thanks
Old 01-10-2015, 02:01 AM   #6
Captainfab
60-66 Nut
Re: help!help!
Why would you want to go from a truck 12 bolt to an older differential that is getting more difficult to get parts for and that most likely has a lower gear than your 12 bolt? The '59 Eaton HO32/33 will be setup for leaf springs. Your '63 should have trailing arms and coil springs.
