Old 01-13-2015, 10:18 PM   #1
gasmn1620
rebuilding my entire front end... advice
Ok, I'll be replacing upper and lower a-arms with new ball joints, drop spindles ( probably mcgaughys unless there is a better option), new tie rod ends, new shocks, drop springs, all new brakes, and all of the wheel bearings. What brands would you guys recommend for the bearings, drop shocks, springs, and spindles. The a-arms will be junkyard rebuilds. I have energy suspension bushings for the whole truck. Someone said to swap the pitman arm out while I'm in there. Any other suggestions. Gotta get this done because my front end is roaring from the bad bearing and old rusty brakes.
gasmn1620 is offline   Reply With Quote
