Please help. What is this part?
So had to take brake booster and master cylender off to install headers and when i did so i broke a fitting where the metal brake ling threads in well it is complety broken and cant get part out wondering if i even need this part i cant find it ANYWHERE..truck does have a fifth wheel hitch maybe was for brake lines to it??? Its the round looking thing in picturs
PLEASE ANY INPUT ASAP would be MUCH appreciated
IF ONE MAN BUILT IT, I CAN FIX IT. |
![]() Join Date: Dec 2013
Re: Please help. What is this part?
does that truck still have the break control , under the dash , I think what you have there is a pressure control for the trailer brake unit , the older trucks had hyd. type vrs the new truck of today being all electric , this unit you adjust the end knurled nob to gain more pressure or less
Brake proportion ing valve
Brake proportioning valve
So any problems with just removing it temporarily?
Thank yall much btw
Thank yall much btw
Define temporarily.
Old member
My opinion.
If your not going to be hauling any loads with a trailer I would remove it and never reinstall it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Andy is correct. If you never intend to haul a trailer, or heavy loads you should be fine. You may experience a different wear rate on front and rear brakes than you have seen in the past. If by temporary you mean take it off to access another part, or to paint it, or something else then reinstall it, you wouldn't have any trouble.
Right on guys thank you very much it is appreciated
![]() Join Date: Nov 2006
I have a question regarding the removal of this component. Wouldn't it be a good idea to do a hard braking test (in an appropriately safe place) after removing it to make sure the vehicle won't try to swap ends? I think I'd want to make sure of that any time a change was made that might affect the brake bias.
