Tahoe Limited questions
I just picked up 2000 Tahoe limited (88-99 body style in case that is not implied
).I read that the Limited's have the body mounted 2" lower on the frame than on the 4x4's, but are all 2-wheel drive Tahoes/Yukons the same thing, or is the body 2" lower than a 2-wheel drive also? If some one has a Limited that has not been lowered, can you give me a measurement from the center of the wheel to the edge of the fender well. I am pretty mine has been lowered but I am not sure how much. I know the rear has at least a shackle, but it is very long. The rear spring has a negative arch, and it is much higher in the back than the front (slopes down from rear to front) so I am thinking it is shackle and no hanger? Anything I need to look out for or need to know? Thanks!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
| Bookmarks |
