Old 01-22-2015, 12:25 AM   #1
Jaysonb
Jaysonb's Avatar
Door jamb wire tube
I am going to put some speakers in my doors, I have manual locks and windows. I was hoping someone could snap a picture of where the wires pass through the jamb on power doors. It looks like lmc sells the rubber tubes. I think it might be to shabby to just run the bare wires through the jamb. Thanks in advance.
Jaysonb is offline   Reply With Quote
Old 01-22-2015, 10:03 AM   #2
tylerg85
Re: Door jamb wire tube
I'll post one for you when I go to lunch
tylerg85 is offline   Reply With Quote
Old 01-22-2015, 10:45 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
I got a couple of good ones here lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-22-2015, 11:04 PM   #4
Jaysonb
Jaysonb's Avatar
Thanks. Looks to be centered between the top and bottom hinges.
Old 01-22-2015, 11:12 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
I believe the holes are dimpled
John
Old 01-22-2015, 11:25 PM   #6
chengny
chengny's Avatar
If you look closely, a truck that did not come from the factory with PL/PW will have a series of 4 dimples on the door jamb:
Use the top and bottom ones as guides for positioning the flexible conduit flange on the cab side. They line right up with the holes in an OEM flange. Just drill them out and pop rivet the flange in place.
I forget whether there is a corresponding set of dimples on the door.
chengny is offline   Reply With Quote
