Old 08-22-2003, 09:28 PM   #1
Chevy4Life
Chevy4Life's Avatar
Question '67 rear bag and c-notch install questions
O.K. I have my rear bags and c-notch. Looks like I'll need one 3/8" bolt coming up through the trailing arm into the bottom of the bag. Then I'll need to drill through the frame, crossmember, and c-notch. Two 3/8" holes and one 1" hole for the top mounts and air line. Is this correct? Is there anything else I need to know? What do you guys use to cut the air line hole?
Thanks,
Jay
Chevy4Life is offline   Reply With Quote
Old 08-22-2003, 11:01 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I WOULD USE A UNIBIT AS THEY LEAVE A VERY CLEAN HOLE. ALSO CALLED A STEP UP BIT.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 08-23-2003, 06:42 PM   #3
Chevy4Life
Chevy4Life's Avatar
Thanks Phantom Dually! I should have thought of that.
