Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-30-2015, 08:10 PM   #1
lwb82c10
big block headers for 73-87 1/2 ton ?
im looking for big block long tube or Fenderwell headers for my 82 c10,
Im doing my engine swap this spring and im collecting parts now. any help will be greatly appreciated.
LWB 82 c10 building a street/strip truck. has a 468 with stock 12 bolt.
lwb82c10 is offline   Reply With Quote
Old 01-31-2015, 12:29 AM   #2
Captainfab
60-66 Nut
Re: big block headers for 73-87 1/2 ton ?
Is there a reason that you don't want to use an off the shelf header such as the Hedman 69110 or one of it's variations?
Old 01-31-2015, 01:31 AM   #3
lwb82c10
I was looking for bigger primary tubes like 1 7/8'' or 2'' but thanks for the part # on the hedman's
Old 02-01-2015, 12:57 AM   #4
Captainfab
60-66 Nut
A set of Chevelle headers will work in a truck chassis and will be easier to find in the primary size you want. There is a thread here somewhere showing the Chevelle headers some guys are using.
Old 02-01-2015, 12:22 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
I'm using chevelle headers on my '69, mainly due to the truck being so low, any full length truck headers would've been about an inch of the ground while driving. I'm using hedman Elites for a chevelle and they tuck up nice and tight - the don't hang down lower than the framerails. A-arm clearance is good, but depending on the motor mounts you're using, you may have to trim the bracket that bolts the engine if you're using clamshell style mounts. I'm using the '72 only clamshell mounts and had to notch the bracket on the driver's side a bit, but it turned out fine.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-01-2015, 01:05 PM   #6
lwb82c10
This is what im looking at
http://www.summitracing.com/parts/hok-2455hkr
Old 02-02-2015, 11:40 AM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
Here's a look at the hedmans.
Adam
Old 02-02-2015, 04:10 PM   #8
lwb82c10
Is this the header part #68198 and that's a nice truck.
http://www.summitracing.com/parts/hed-68198/overview/
Old 02-02-2015, 05:11 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Yep, that's them. I would've liked to have 1 7/8", but the fit of these was really nice and they are very well built. I probably won't miss the 10hp or so I lost.
Adam
