Old 02-02-2015, 05:06 PM   #1
IdahoMan
Vent Control Assembly
I'm trying to take off a kick-panel, there is a vacuum-driven switch there with a spring and a metal arm attached to the vent. The spring slips off, but what about the arm? It's like it is permanently attached. Picture bellow.
Thanks.
IM
IdahoMan is offline   Reply With Quote
Old 02-02-2015, 05:14 PM   #2
Ric's/86
Re: Vent Control Assembly
Just pry the small washers off. Put some lubricant. Be gentle or you will break them.
Ric's/86 is offline   Reply With Quote
Old 02-02-2015, 05:19 PM   #3
IdahoMan
Yeah. I played with them with my fingers. I expected some play, but it's very solid; wouldn't even wiggle. I'll try again.
Old 02-02-2015, 06:04 PM   #4
Ric's/86
Needle nose pliers or flat screwdriver. I done a couple like that.
Old 02-02-2015, 06:07 PM   #5
Ric's/86
Take the panel off the truck so you can work better.
Old 02-02-2015, 06:32 PM   #6
IdahoMan
Can't take the panel off until the vacuum switch is removed. Can't remove the vacuum switch until arm is disconnected.
Old 02-02-2015, 07:35 PM   #7
Ric's/86
Remove the vacuum line from the diaphragm, then remove the entire plastic panel.
Old 02-02-2015, 07:53 PM   #8
Ric's/86
Like this
Old 02-02-2015, 09:51 PM   #9
IdahoMan
Like this
Thanks. I thought the screws there held the panel to the body.
