Old 02-05-2015, 02:58 PM   #1
rs74
rs74's Avatar
Any threads on King Pin replacement?
I think I have a bearing going bad on my D60 and I also have the death wobble. So while I am in there doing the bearings I might as well do the king pin kit or whatever I need to fix it. I have never been into any axle to this extent. So if there are any write ups on any of this it sure would be helpful.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-05-2015, 03:28 PM   #2
crashz
crashz's Avatar
Re: Any threads on King Pin replacement?
The Dana60 is not exactly a logical set-up, but in my opinion, easier to service than other front axles with ball joints. Outers are pretty much the same. Dana/Spicer sells the king pin service kits with bearings, cups, and seals. My K25 has a swapped in D60 and has custom bronze cups that an old family friend made for me.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 02-05-2015, 03:31 PM   #3
rs74
rs74's Avatar
I found this set so far. https://www.4wdfactory.com/store/pro...r-Dana-60.html
Roy
1987 R10 shortie
Old 02-05-2015, 03:36 PM   #4
mrolds88
This should help. http://www.pirate4x4.com/tech/billav...pin/index.html
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-05-2015, 03:43 PM   #5
rs74
rs74's Avatar
Originally Posted by mrolds88 View Post
Lol! I just got done reading that. That's is how I found out about the 4wdfactory .com kit. Thanks! I appreciate that.
Roy
1987 R10 shortie
Old 02-09-2015, 11:33 AM   #6
rs74
rs74's Avatar
I have a call in to order the service kit and hopefully they carry the wheel bearings to from this place.
I knew the king pin needed replaced and I was buying time on that but I believe the wheel bearing is going out so I might as well do it all at the same time. Just doing the drivers side for now. I will get that done then order the kit and bearings for the other side then start ordering Moog tie rods from Rockauto.
Roy
1987 R10 shortie
