Suburban and truck frame
I would like to eventually replace my font crossmember and suspension parts... Found a suburban front end for cheap, so i thought about powdercoating while i can still have mine on. Is the a difference... I know the rear is different
Re: Suburban and truck frame
I can't swear to it, but I think the front crossmember and a-arms are the same. I used the parts from an 81 suburban to give my 64 suburban disc brakes. Pretty much a bolt-together affair.
I did the same as you, sand blasting everything, and replacing every ball joint and bushing while it was all apart. Boy, that new front-end is tight!
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
Yes, I put an '89 Suburban 1500 crossmember, suspension, spindles and brakes on an '84 C-10 frame with no problems. Even gave me the 1.25 inch rotors.
That is what i was hoping to hear.. Thank for the replies
Robert Olson Transport
![]() Join Date: Oct 2002
better check ore into that... I wanted to put a bur trailer hitch on a pickup and it was too wide but again this is the rear we are talking about
Yes, the rear part of the frame angles downward making the hitches different. Also the gas tank area, rear spring hangers and body mounts. It would be safe to say Suburban frames are different from the transmission crossmember back.
![]() Join Date: Jun 2009
The front is the same from pick up to suburban
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
| Bookmarks |
